1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw
Date: Wed, 6 Jun 2012 20:58:09 +0000
All,
I am attempting to build EPICS 3.14.12.2 on a Windows XP machine using mingw32.
EPICS_HOST_ARCH = win32-x86-mingw
I type”make” at the top level directory (c:\epics).  Make is GNU Make version 3.81
I get an error: /bin/ld.exe: cannot find -lrtemscpu
The closest matching file I have on my machine is librtemscpu.a.
What is lrtemscpu?   Do I need to build a separate package to generate it?
Any help much appreciated.
- Yoram Fisher –
make[3]: Entering directory `/c/epics/src/libCom/test/O.win32-x86-mingw'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/c/epics/src/libCom/test/O.win32-x86-mingw'
make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../../.. T_A=RTEMS-uC5282 install
make[3]: Entering directory `/c/epics/src/libCom/test/O.RTEMS-uC5282'
/c/opt/rtems-4.10/bin/m68k-rtems4.10-g++ -o rtemsTestHarness -static -L/c/epics/
lib/RTEMS-uC5282         -mcpu=5282 -u Init /lib/no-dpmem.rel /lib/no-mp.rel /li
b/no-part.rel /lib/no-signal.rel /lib/no-rtmon.rel            rtemsTestHarness.o
epicsCalcTest.o epicsAlgorithmTest.o epicsMathTest.o epicsEllTest.o epicsErrlog
Test.o epicsStdioTest.o epicsStringTest.o epicsTimeTest.o epicsThreadTest.o epic
sThreadOnceTest.o epicsThreadPriorityTest.o epicsThreadPrivateTest.o epicsExitTe
st.o epicsTimerTest.o ringPointerTest.o ringBytesTest.o epicsEventTest.o epicsMu
texTest.o epicsExceptionTest.o macEnvExpandTest.o macLibTest.o taskwdTest.o bloc
kingSockTest.o epicsMessageQueueTest.o epicsRunLibComTests.o epicsThreadPerform.
o epicsMaxThreads.o buckTest.o cvtFastPerform.o    -lCom       -lm -lrtemsCom -l
c -lrtemscpu -lCom -lnfs -lm
c:/opt/rtems-4.10/bin/../lib/gcc/m68k-rtems4.10/4.4.7/../../../../m68k-rtems4.10
collect2: ld returned 1 exit status
make[3]: *** [rtemsTestHarness] Error 1
make[3]: Leaving directory `/c/epics/src/libCom/test/O.RTEMS-uC5282'
make[2]: *** [install.RTEMS-uC5282] Error 2
make[2]: Leaving directory `/c/epics/src/libCom/test'
make[1]: *** [libCom/test.install] Error 2
make[1]: Leaving directory `/c/epics/src'
make: *** [src.install] Error 2
Yoram Fisher
Senior Systems Engineer
Sydor Instruments, LLC
291 Millstead Way
Rochester, New York 14624
Ph: +1.585.278.1168,   Fax: +1.585.278.1169
Email: [email protected]
web:  www.sydorinstruments.com
Re: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Eric Norum
Re: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Andrew Johnson
Prev: Re: [CSS] text edit + Go! button Pavel Masloff
Next: Re: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Two DBD utility functions Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
