1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [CSS] text edit + Go! button
To: "Kasemir, Kay" <[email protected]>
Date: Wed, 6 Jun 2012 16:39:06 +0400
What about the second option?
How will the script look like?
On Wed, Jun 6, 2012 at 4:20 PM, Kasemir, Kay <[email protected]> wrote:
You could
1) Have the text entry widget write to a PV on the IOC that does nothing,
then have the 'Go' button write to another PV's PROC field, that that other PV could be an AO record
with DOL = first PV, OUT = final PV.
So pushing the button will actually cause the value from the text to be written to the final PV.
Can have any number of FLNKs to trigger a whole lot of stuff, and this would work with EDM, CSS BOY, ...
2) Have the text entry field write to a loc://.. local PV, have the button run a script that reads from the loc://.. PV and writes to the real PV.
This will only work in CSS BOY, but is much simpler and doesn't require anything special on the IOC.
-Kay
From: Pavel Masloff <[email protected]<mailto:[email protected]>>
To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
Subject: [CSS] text edit + Go! button
Is there a way in CSS using whatever, but scripts create a text edit widget and a Go! button, so you first fill in the PV value (nothing happens), and once you click on the button it writes the text you typed in one (or a few) records (PVs)?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Re: [CSS] text edit + Go! button Kasemir, Kay
[CSS] text edit + Go! button Pavel Masloff
Prev: Two DBD utility functions Dirk Zimoch
Next: Re: [CSS] text edit + Go! button Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [CSS] text edit + Go! button Kasemir, Kay
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
