1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Proposed change in asyn - request for comments
Date: Fri, 1 Jun 2012 16:27:32 -0700
Interesting!
I can see how that could be quite useful!
As we don't use post_event() for that purpose, I just
assumed it was a general purpose signaling mechanism.
It also works quite nicely for that purpose, as I used it to
implement a history mechanism in our EDT frame grabber.
- Bruce
On 6/1/2012 7:55 AM, Andrew Johnson wrote:
Hi Bruce,
On 2012-05-31 Bruce Hill wrote:
My concern was that overloading the TSE field to contain EVR Event codes
would be inappropriate for a module like asyn that is used by many sites
that don't use EVR's.
The TSE and TSEL fields were originally /designed/ for use with timing system
event codes.  The Record Reference Manual describes the TSE field thus:
     This indicates the mechanism to use to get the time stamp. '0' - call
     get time as before '-1' - call the time stamp driver and use the best
     source available. '-2' - the device support provides the time stamp
     from the hardware. Values between 1-255 request the time of the last
     occurrence of a generalTime event.
   https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon
I agree that this mechanism is not currently much use on systems that don't
use an event timing system, although it would be quite feasible to write a
plugin for the generalTime event subsystem that provides global event times
from UDP packets.
- Andrew
Proposed change in asyn - request for comments Mark Rivers
RE: Proposed change in asyn - request for comments Kim, Kukhee
Re: Proposed change in asyn - request for comments Bruce Hill
Re: Proposed change in asyn - request for comments Andrew Johnson
Prev: adding a prefix to all PV names with macro substitution Martin Konrad
Next: Re: adding a prefix to all PV names with macro substitution Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Proposed change in asyn - request for comments Williams Jr., Ernest L.
Next: Re: Proposed change in asyn - request for comments Michael Davidsaver
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
