1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [StreamDevice] parsing rapid inputs
To: Pavel Masloff <[email protected]>
Date: Thu, 31 May 2012 17:35:55 +0200
Hi Pavel,
Try to increase ReadTimeout. It seems that sometimes your device takes some time between sending the message and sending the \r.
Dirk
Pavel Masloff wrote:
Hello,
I have run into a problem lately. I have sort of a slow device - a TDS2024 scope. So when I run my IOC, I expect StreamDevice to initialize my PVs. So there are ~ 20 PVs I want to initialize. And every once in a while I get the following error message in epics shell:
/2012/05/30 13:02:25.211 L2 TDS2024:probe_ch2: got "<0d>:CH2:PROBE 1" where ":CH2:PROBE " was expected
/This <0d> character (or CR) is driving me mad. This is because it was supposed to be the terminator of the previous input (here is the whole string together with the one above):
/2012/05/30 13:02:25.124 /dev/ttyUSB0 read 13
:CH1:PROBE 1\n
//2012/05/30 13:02:25.211 L2 TDS2024:probe_ch2: got "<0d>:CH2:PROBE 1" where ":CH2:PROBE " was expected/
As you can see, there is an \r missing. So my <0d> comes as a part of the input /":CH2:PROBE 1" /- so I get /"<0d>:CH2:PROBE 1" /instead which causes the error.
How can I fix this?
I have tried using the @mismatch handler, but it doesn't work within the @init handler.
And you will never know which PV will not initialize next.
As an comparison, my TPS2024 and TPS2024B scopes are fast enough to stumble upon this. No problem there.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Land line: +7 (812) 461 01 01
[StreamDevice] parsing rapid inputs Pavel Masloff
Prev: Re: [CSS] commas in TextUpdate Pavel Masloff
Next: Re: errro running "ibtest" Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [StreamDevice] parsing rapid inputs Dirk Zimoch
Next: Problem when caput to waveform record 王林
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
