1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: errro running "ibtest"
To: [email protected]
Date: Thu, 31 May 2012 11:03:09 +0800 (CST)
Hi, everyone:
I'm trying to connect a GPIB device via LINUX-GPIB.The driver for NI GPIB card had been setup successfully.When testing with "ibtest" ,I got the erro:
[root@localhost etc]# ibtest
Do you wish to open a (d)evice or an interface (b)oard?
        (you probably want to open a device): d
enter primary gpib address for device you wish to open [0-30]: 3
trying to open pad = 3 on /dev/gpib0 ...
You can:
        w(a)it for an event
        write (c)ommand bytes to bus (system controller only)
        send (d)evice clear (device only)
        change remote (e)nable line (system controller only)
        (g)o to standby (release ATN line, system contro! ller only)
        send (i)nterface clear (system controller only)
        ta(k)e control (assert ATN line, system controller only)
        get bus (l)ine status (board only)
        go to local (m)ode
        change end (o)f transmission configuration
        (q)uit
        (r)ead string
        perform (s)erial poll (device only)
        change (t)imeout on io operations
        request ser(v)ice (board only)
        (w)rite data string
: w
enter a string to send to your device: :CHANnel1:CURRent 0.5
sending string: :CHANnel1:CURRent 0.5
gpib status is:
ibsta = 0x8100  < ERR CMPL >
iberr= 0
EDVR 0: OS error
ibcnt = 25
Is there anything I missed?
Re: errro running "ibtest" Rod Nussbaumer
Prev: RE: Proposed change in asyn - request for comments Kim, Kukhee
Next: Re: Proposed change in asyn - request for comments Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ether_ip problem reading DINT arrays Bob Gunion
Next: Re: errro running "ibtest" Rod Nussbaumer
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
