1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: calc VAL field not updating from bi VAL field
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Wed, 30 May 2012 11:37:38 -0700
On May 30, 2012, at 10:25 AM, Tim Mooney wrote:
> It seems that the integer to double conversion really is not exact for 1.
That seems like a pretty huge flaw in the architecture!  I've never encountered a machine with arithmetic that bad!
I suspect the problem is somewhere else.    Could it be that the bi record is accepting any non-zero value as 'true' -- so that when read as an integer the value is not '1' as the code expects?
>  If so, it wouldn't be exact for either 1.
> Could you try "nint(a)=nint(1)?1:0"
Eric Norum
[email protected]
Re: calc VAL field not updating from bi VAL field Maren Purves
Re: calc VAL field not updating from bi VAL field Tim Mooney
Prev: Re: Proposed change in asyn - request for comments Eric Norum
Next: RE: Proposed change in asyn - request for comments Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Next: Re: calc VAL field not updating from bi VAL field Maren Purves
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
