1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: calc VAL field not updating from bi VAL field
To: [email protected]
Date: Wed, 30 May 2012 11:11:20 -0500
Hi Lewis,
On 2012-05-30 Allison, Stephanie wrote:
> Could this be a round-off error (long to double)?  Does this CALC work:
> field(CALC, "A>0.5?1:0")
If that works, also try the expression "!!A" which is more efficient than
using ?: anyway.  In general I never assume that a true value is 1, it's
better to check for non-zero, so use "A!=0?1:0" or just "A?1:0".
However I admit I would be very surprised if the integer to double conversion
is not exact for the value 1.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: calc VAL field not updating from bi VAL field J. Lewis Muir
RE: calc VAL field not updating from bi VAL field Allison, Stephanie
Prev: RE: Proposed change in asyn - request for comments Mark Rivers
Next: Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: calc VAL field not updating from bi VAL field Allison, Stephanie
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
