Hi Lewis -
Could this be a round-off error (long to double)? Does this CALC work:
field(CALC, "A>0.5?1:0")
Stephanie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of J. Lewis Muir
> Sent: Tuesday, May 29, 2012 8:10 PM
> To: EPICS Tech Talk
> Subject: calc VAL field not updating from bi VAL field
> I've got a problem where a calc record's VAL field is not
> updating when I expect it to.
> I load the following database into my IOC:
> calc-bi.db >>>
> record(bi, "$(P)Unidig1Bi1") {
> field(ZNAM, "Low")
> field(ONAM, "High")
> record(calc, "$(P)ClcBacklightBi") {
> field(INPA, "$(P)Unidig1Bi1.VAL CP MS")
> field(CALC, "A=1?1:0")
> like this:
> st.cmd >>>
> dbLoadRecords("calc-bi.db","P=17lab:")
> I then start camonitor:
> camonitor console >>>
> $ camonitor 17lab:ClcBacklightBi.VAL 17lab:ClcBacklightBi.A
> 17lab:ClcBacklightBi.VAL 2012-05-29 19:48:44.845452 1 LINK
> INVALID
> 17lab:ClcBacklightBi.A 2012-05-29 19:48:44.845452 0 LINK
> INVALID
> And then I perform a series of caput commands in another console:
> caput console >>>
> $ caput 17lab:Unidig1Bi1.VAL 0
> Old : 17lab:Unidig1Bi1.VAL Low
> New : 17lab:Unidig1Bi1.VAL Low
> $ caput 17lab:Unidig1Bi1.VAL 1
> New : 17lab:Unidig1Bi1.VAL High
> Old : 17lab:Unidig1Bi1.VAL High
> camonitor shows the following:
> 17lab:ClcBacklightBi.VAL 2012-05-29 21:11:28.307312 1
> 17lab:ClcBacklightBi.A 2012-05-29 21:11:28.307312 0
> 17lab:ClcBacklightBi.A 2012-05-29 21:11:33.423978 1
> 17lab:ClcBacklightBi.A 2012-05-29 21:11:36.990645 0
> 17lab:ClcBacklightBi.A 2012-05-29 21:12:32.507352 1
> As you can see, the 17lab:ClcBacklightBi record's VAL field
> updates once when the record first processes and then never
> again. The "A" field is updating correctly as I change
> 17lab:Unidig1Bi1.VAL, but 17lab:ClcBacklightBi.VAL never updates
> again.
> If I change the CALC expression to "A", the VAL field updates
> correctly. If I change it back, it stops working again.
> Environment:
> * VME processor module: Motorola MVME-2100 (vxWorks-ppc603)
> - CPU: MPC 8240
> - Memory: 32 MB
> * OS: VxWorks 5.5.2
> * Kernel: WIND 2.6
> * BSP: mv2100-asd5 (by Andrew Johnson)
> * Build toolchain: Tornado 2.2.2
> * EPICS 3.14.12.2 (+Known Problems patches)
> I tried this on darwin-x86 (x86_64) and it did not fail, so to
> date it is only failing for me on my VME systems. (I initially
> discovered the problem on an MVME-5100.)
> This worked fine with older software (i.e. VxWorks 5.4.2 with
> EPICS 3.14.11) on my VME systems.
> Thanks,
> Lewis
- Re: calc VAL field not updating from bi VAL field Andrew Johnson
- Re: calc VAL field not updating from bi VAL field J. Lewis Muir
- calc VAL field not updating from bi VAL field J. Lewis Muir
Re: Proposed change in asyn - request for comments Eric Norum
Re: Proposed change in asyn - request for comments Michael Davidsaver
<2012>
<2012>
