1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: [StreamDevice] parsing rapid inputs
To: "'Pavel Masloff'" <[email protected]>
Date: Wed, 30 May 2012 14:10:32 +0000
I don’t know about the output EOS, that depends what the scope expects.  But it looks like it is definitely sending you \n\r, so you should set the InputEos to “\n\r”.
Sent: Wednesday, May 30, 2012 9:09 AM
To: Mark Rivers
Cc: Dirk Zimoch; EPICS Tech Talk
Subject: Re: [StreamDevice] parsing rapid inputs
Hi Mark,
asynOctetSetInputEos("${PORT1}", -1, "\n")
asynOctetSetOutputEos("${PORT1}", -1, "\n")
Should I set them both to "\n\r"?
On Wed, May 30, 2012 at 6:00 PM, Mark Rivers <[email protected]> wrote:
How have you set the input EOS on your asyn port?  Have you overridden this by explicitly defining a terminator in your stream protocol file?
If you define the terminator as “\n\r” for the asyn port and don’t define it in your protocol file then I don’t think you should have this problem, because the read won’t complete until it finds and consume the \r (CR) character.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Wednesday, May 30, 2012 3:15 AM
To: Dirk Zimoch; EPICS Tech Talk
Subject: [StreamDevice] parsing rapid inputs
Hello,
I have run into a problem lately. I have sort of a slow device - a TDS2024 scope. So when I run my IOC, I expect StreamDevice to initialize my PVs. So there are ~ 20 PVs I want to initialize. And every once in a while I get the following error message in epics shell:
2012/05/30 13:02:25.211 L2 TDS2024:probe_ch2: got "<0d>:CH2:PROBE 1" where ":CH2:PROBE " was expected
This <0d> character (or CR) is driving me mad. This is because it was supposed to be the terminator of the previous input (here is the whole string together with the one above):
2012/05/30 13:02:25.124 /dev/ttyUSB0 read 13
:CH1:PROBE 1\n
As you can see, there is an \r missing. So my <0d> comes as a part of the input ":CH2:PROBE 1" - so I get "<0d>:CH2:PROBE 1"  instead which causes the error.
How can I fix this?
I have tried using the @mismatch handler, but it doesn't work within the @init handler.
And you will never know which PV will not initialize next.
As an comparison, my TPS2024 and TPS2024B scopes are fast enough to stumble upon this. No problem there.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Land line: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Landline: +7 (812) 461 01 01
Re: [StreamDevice] parsing rapid inputs Dirk Zimoch
[StreamDevice] parsing rapid inputs Pavel Masloff
RE: [StreamDevice] parsing rapid inputs Mark Rivers
Re: [StreamDevice] parsing rapid inputs Pavel Masloff
Prev: Re: [StreamDevice] parsing rapid inputs Pavel Masloff
Next: Re: Problem when caput to waveform record Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: [StreamDevice] parsing rapid inputs Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
