1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms"
Cc: Eric Norum <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 25 May 2012 14:19:00 -0500
On 5/25/12 1:18 PM, Mark Rivers wrote:
> Lewis,
> I think your point and Dirk's are rather different.  You are
> saying "don't support old releases of modules you are
> responsible for".  Fine.  But Dirk is saying "do write your
> module X so it supports old versions of module Y that someone
> else is responsible for".  In the case of streamDevice that
> means old versions of base and asyn.
> In the case of more complex modules like areaDetector, it
> would potentially mean I should support old versions of base,
> asyn, calc, busy, sscan, and autosave.
> I just don't think that's realistic or a good use of my
> limited time.
Hi, Mark.
OK, maybe I misunderstood what Dirk was saying.  I agree that it
can be very time consuming to do Dirk's approach, and I agree
that, with limited time, it might not be the best choice, but
I'm just saying what Dirk did is nice because StreamDevice is
able to work with older versions of libraries which means I
could potentially upgrade just StreamDevice and nothing else.
What I thought Dirk was talking about was the concept of binary
compatibility and trying not to break that for a reasonable
amount of time.  There's a write-up about that at
http://apr.apache.org/versioning.html
.  I like this and think it would make dealing with all the
EPICS related libraries out there a lot easier because I could
very quickly tell what versions of libraries I could expect to
upgrade and still work correctly with one another.  And it would
require developers to be aware of binary compatibility since
they'd have to increment the right version number part.  Now I
just need to convince everyone to adopt this versioning scheme. :-)
Lewis
On compatibility Dirk Zimoch
"@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" 洪春霞
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Andrew Johnson
Re: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms" J. Lewis Muir
RE: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms" Mark Rivers
Prev: RE: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms" Mark Rivers
Next: NDArrayData Access Yingbing Yan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: On compatibility Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
