1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: medm and Xming on Windows 7 64 bit
To: "'Troy Lutes'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 24 May 2012 17:37:39 +0000
Hi Troy,
I am quite sure I ran into that same problem on a Windows 7 32-bit system recently.
I worked around the problem by not installing the 2011 1.42 or 1.41 builds of the EPICS Windows Tools, but rather installing the 1.40 build from 2007.  I did not take much time to investigate, but I'm quite sure that worked.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Troy Lutes
Sent: Wednesday, May 23, 2012 3:04 PM
To: [email protected]
Subject: medm and Xming on Windows 7 64 bit
We are setting up an IOC for HPSync. The IOC seems to startup fine, but there are problems with the display. We have installed Xming as described in:
http://controls.web.psi.ch/cgi-bin/twiki/view/Main/HowToSetupEPICSWin32
Probe, alarm handler, strip tool, etc all work fine from the icons in the win32 tools folder.
Medm gives the following error in the Xconsole
[medm]
MEDM Version 3.1.5: Loading aliased fonts.................
SIGSEGV
Does anybody have experience with Xming and medm?
Thanks in advance,
Troy
Troy Lutes
Linux Systems Administrator
Advanced Photon Source
Argonne National Laboratory
(630)252-1345
Re: medm and Xming on Windows 7 64 bit Pavel Masloff
medm and Xming on Windows 7 64 bit Troy Lutes
Prev: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
Next: Re: medm and Xming on Windows 7 64 bit Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: medm and Xming on Windows 7 64 bit Paul Sichta
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
