1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater
To: Dirk Zimoch <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 23 May 2012 10:03:14 -0700
On 05/23/2012 08:49 AM, Dirk Zimoch wrote:
Michael Davidsaver wrote:
   On 5/22/2012 9:07 PM, Ernest L. Williams Jr. wrote:
We build our target as a CROSS, so caRepeater only gets built for HOST
builds.
Was there something which required this?
I have put this into all of my embedded Linux cross CONFIG.Common.* files:
VALID_BUILDS = Host Ioc
Now it builds caRepeater, caget, caput (and more things you won't need:
antelope -- does not hurt).
Hi Dirk,
That works like a charm. :)
[ernesto@lcls-dev2 ca]$ make CROSS_COMPILER_TARGET_ARCHS=linuxRT-x86
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-12/src/ca/O.linux-x86'
make[1]: Nothing to be done for `install'.
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-12/src/ca/O.linux-x86'
make -C O.linuxRT-x86 -f ../Makefile TOP=../../.. T_A=linuxRT-x86 install
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-12/src/ca/O.linuxRT-x86'
Installing created file ../../../bin/linuxRT-x86/caRepeater
Cheers,
Ernest
Dirk
embedded linux target with uClibC and PREEMPT_RT needs caRepeater Ernest L. Williams Jr.
Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Michael Davidsaver
Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Dirk Zimoch
Prev: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Ernest L. Williams Jr.
Next: Allen-Bradley Ethernet/IP driver and CompactLogix PLC's Elliott Wolin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Rod Nussbaumer
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
