1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater
To: Rod Nussbaumer <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 23 May 2012 08:40:08 -0700
On 05/23/2012 07:56 AM, Rod Nussbaumer wrote:
Ernest:
It sounds like your question is the same as one I posed earlier, and
Andrew's reply may be helpful:
<http://www.aps.anl.gov/epics/tech-talk/2010/msg00978.php>
Yes, this helps.  :)
I did get most of those already.
However my embedded linux target was complaining about caRepeater.
So, I had to make change in here:
base/src/ca/Makefile
All is well, now. :)
Cheers,
Ernest
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Ernest L. Williams Jr. wrote:
I found that I need to have caRepeater available for my target but EPICS
BASE does not build it.
How have others done this?
We build our target as a CROSS, so caRepeater only gets built for HOST
builds.
Now for vxWorks and RTEMS, they use "repeater.cpp" which gets linked in.
What I have done for our embedded linux target is the following, is this
acceptable?
Modify,<BASE>/src/ca/Makefile
And added:
ifeq ($(T_A),linuxRT-x86)
   PROD_DEFAULT += caRepeater catime acctst caConnTest casw caEventRate
endif
Then, I did a build like so,
make CROSS_COMPILER_TARGET_ARCHS=linuxRT-x86
Thanks in advance for your comments and help.
Cheers,
Ernest
embedded linux target with uClibC and PREEMPT_RT needs caRepeater Ernest L. Williams Jr.
Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Rod Nussbaumer
Prev: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Rod Nussbaumer
Next: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: CSS BOY EDL --> OPI giles.knap
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
