THe solution was to put everything in /etc/bashrc. Thanks Lewis.
On Mon, May 21, 2012 at 11:20 AM, Pavel Masloff <[email protected]> wrote:
Mark,
it's missing in epicsPrtEnvParams !!!
Then I stop the IOC -> issue export EPICS_CA_MAX_ARRAY_BYTES=50000 -> start the IOC -> epicsPrtEnvParams. And now it's there.
Mystic...
At the IOC prompt type the command
epicsPrtEnvParams
That will tell you what all of the EPICS environment variables are actually set to for the IOC.
On Behalf Of Pavel Masloff
Sent: Friday, May 18, 2012 8:52 AM
To: EPICS Tech Talk
Subject: [CA][waveform]max array bytes on IOC
It is very strange when I manually export the EPICS_CA_MAX_ARRAY_BYTES environmental variable on the IOC (export VAR=wahteverval), my waveforms on the client are connected.
When I put this line to /root/.bashrc the client doesn't want to connect my waveform PVs....
What's wrong?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus
-- Best regards,
- [CA][waveform]max array bytes on IOC Pavel Masloff
- RE: [CA][waveform]max array bytes on IOC Mark Rivers
- Re: [CA][waveform]max array bytes on IOC Pavel Masloff
New sequencer snapshot / release candidate Benjamin Franksen
Modbus R2-4 available Mark Rivers
<2012>
[edm] error Pavel Masloff
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
