1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: [CSS] commas in TextUpdate
To: Pavel Masloff <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 21 May 2012 09:19:11 -0400
Hi Pavel,
CSS will only get the whole array of the waveform regardless NORD. In case of String Waveform, it is empty string after NORD of elements, so you see ,,,,,,.  If you really don’t want to see these commas, you can cut the array with NORD in a script. See /BOY Examples/Miscellaneous/ArraysOperation/PlotFirstNPointsExample.opi
Xihui
Sent: Saturday, May 19, 2012 10:21 AM
To: EPICS Tech Talk
Subject: [CSS] commas in TextUpdate
Why I see commas in the TextUpdate widget displaying a waveform when NELM>NORD??
For example, I have a waveform of strings. NELM=10, NORD=3. As a result:
text1, text2, text3,,,,,,,
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
[CSS] commas in TextUpdate Pavel Masloff
Prev: Re: [CSS] commas in TextUpdate Kasemir, Kay
Next: Re: [CSS] commas in TextUpdate Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [CSS] commas in TextUpdate Pavel Masloff
Next: dbReportDeviceConfig bug Hinko Kocevar
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
