g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: [CA][waveform]max array bytes on IOC
To: Mark Rivers <rivers@cars.uchicago.edu>
Cc: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Mon, 21 May 2012 11:20:05 +0400
Mark,
it's missing in epicsPrtEnvParams !!!
Then I stop the IOC -> issue export EPICS_CA_MAX_ARRAY_BYTES=50000 -> start the IOC -> epicsPrtEnvParams. And now it's there.
Mystic...
On Fri, May 18, 2012 at 6:35 PM, Mark Rivers <rivers@cars.uchicago.edu> wrote:
At the IOC prompt type the command
epicsPrtEnvParams
That will tell you what all of the EPICS environment variables are actually set to for the IOC.
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Pavel Masloff
Sent: Friday, May 18, 2012 8:52 AM
To: EPICS Tech Talk
Subject: [CA][waveform]max array bytes on IOC
It is very strange when I manually export the EPICS_CA_MAX_ARRAY_BYTES environmental variable on the IOC (export VAR=wahteverval), my waveforms on the client are connected.
When I put this line to /root/.bashrc the client doesn't want to connect my waveform PVs....
What's wrong?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Re: [CA][waveform]max array bytes on IOC Pavel Masloff
RE: [CA][waveform]max array bytes on IOC Mark Rivers
Prev: [CSS] commas in TextUpdate Pavel Masloff
Next: dbReportDeviceConfig bug Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: [CA][waveform]max array bytes on IOC Pavel Masloff
Next: Re: [CA][waveform]max array bytes on IOC Pavel Masloff
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
