1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: [CA][waveform]max array bytes on IOC
To: "'Pavel Masloff'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 18 May 2012 14:35:47 +0000
At the IOC prompt type the command
epicsPrtEnvParams
That will tell you what all of the EPICS environment variables are actually set to for the IOC.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Friday, May 18, 2012 8:52 AM
To: EPICS Tech Talk
Subject: [CA][waveform]max array bytes on IOC
It is very strange when I manually export the EPICS_CA_MAX_ARRAY_BYTES environmental variable on the IOC (export VAR=wahteverval), my waveforms on the client are connected.
When I put this line to /root/.bashrc the client doesn't want to connect my waveform PVs....
What's wrong?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: [CA][waveform]max array bytes on IOC Pavel Masloff
Prev: Re: [CA][waveform]max array bytes on IOC J. Lewis Muir
Next: RE: using areaDetector as a support library only Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: [CA][waveform]max array bytes on IOC Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
