1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: [EDM] on windows?
To: EPICS Tech Talk <[email protected]>
Date: Fri, 18 May 2012 14:04:02 +0000
Pavel Masloff wrote:
"I can see on some EDM screens people run it on Windows (Windows-like style: close, maximize and minimize buttons).
Is there a detailed explaination on how to do it? Presumably, one should use X-server (Xming).
How do you usually run EDM files?"
Here is what we do: "Run" edm on linux, "Display" on windows using XWin32 or Xming.
I should point out that Xming is free and works, but there are issues.  When you open a 'related display,'  it shows up in focus, but when you open it again, it does not open, nor does the existing window go into focus.
That can be annoying in the control room, where screens are cluttered.
XWin32 is better but costs money, plus there is the overhead of keeping it up-to-date.
In the control room, it's worth it.
Cheers -Mathias
NSCL/Cyclotron Lab
Michigan State University
[EDM] on windows? Pavel Masloff
Prev: [CA][waveform]max array bytes on IOC Pavel Masloff
Next: Re: [CA][waveform]max array bytes on IOC J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: [EDM] on windows? Pavel Masloff
Next: CSS build with Eclipse RCP-3.7 and -pluginCustomization Xinyu.Wu
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
