1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS3.14.12 RTEMS patch for nfsMount() ( was Re: Autosave and RTEMS-4.10)
To: [email protected]
Cc: [email protected], 송영기 <[email protected]>
Date: Tue, 15 May 2012 12:18:12 -0400
It seems like an oversight that nfsMount() command was declared static in rtems_init.c().
The patch below for EPICS3.14.12.x would simply solve the error of
"undefined reference to `nfsMount'  ".  This should be fixed in R3.14.12.2 and higher version too.
diff -Naur R3.14.12.1/src/RTEMS/base/rtems_init.c.orig R3.14.12.1/src/RTEMS/base/rtems_init.c
--- R3.14.12.1/src/RTEMS/base/rtems_init.c.orig    2011-04-26 16:40:09.000000000 -0400
+++ R3.14.12.1/src/RTEMS/base/rtems_init.c    2012-05-15 11:42:57.619344534 -0400
@@ -173,8 +173,7 @@
 #if __RTEMS_MAJOR__>4 || \
    (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__>9) || \
    (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__==9 && __RTEMS_REVISION__==99)
-static int
-nfsMount(char *uidhost, char *path, char *mntpoint)
+int nfsMount(char *uidhost, char *path, char *mntpoint)
     int   devl = strlen(uidhost) + strlen(path) + 2;
     char *dev;
Thus, the original patch for nfs.c in RTEMS-4.10.0 would not need to unblock the nfsMount() command.
diff -a -u nfs.c.orig nfs.c
--- nfs.c.orig    2010-07-01 11:18:06.000000000 -0400
+++ nfs.c    2012-04-26 12:41:25.383414776 -0400
@@ -128,7 +128,6 @@
 /* we use a dynamically assigned major number */
 #define NFS_MAJOR                        (nfsGlob.nfs_major)
 /* NOTE: RTEMS (ss-20020301) uses a 'short st_ino' type :-( but the
  * NFS fileid is 32 bit. [Later versions of RTEMS have fixed this;
  * nfsInit() issues a warning if you run a version with 'short st_ino'.]
@@ -1574,7 +1573,7 @@
         assert( node->args.name );
-        *(const char**)arg = pathname + (node->args.name - p);
+        *(arg->c) = pathname + (node->args.name - p);
 #if 0
         /* restore the directory node */
@@ -2616,6 +2615,9 @@
     if (count > NFS_MAXDATA)
         count = NFS_MAXDATA;
+    if (count > nfsStBlksize)
+        count = nfsStBlksize;
     SERP_ARGS(node).readarg.offset        = iop->offset;
     SERP_ARGS(node).readarg.count          = count;
     SERP_ARGS(node).readarg.totalcount    = UINT32_C(0xdeadbeef);
@@ -2720,6 +2722,8 @@
     SERP_ARGS(node).writearg.beginoffset   = UINT32_C(0xdeadbeef);
     if ( LIBIO_FLAGS_APPEND & iop->flags ) {
@@ -3247,8 +3251,8 @@
     return 0;
Cheers,
Kate
On 04/26/2012 12:50 PM, Kate Feng wrote:
If one use RTEMS4-10.0, one needs to apply the patch below for the cpukit/libfs/src/nfsclient/src/nfs.c,
in addition to https://www.rtems.org/bugzilla/show_bug.cgi?id=1797 and
https://www.rtems.org/bugzilla/show_bug.cgi?id=1786
Cheers,
Kate Feng
@@ -128,7 +128,6 @@
 #if 0
     return 0;
-#if 0
-CCJ_REMOVE_MOUNT
+#if 1
+/*CCJ_REMOVE_MOUNT*/
 /* convenience wrapper
  * NOTE: this routine calls NON-REENTRANT
@@ -3328,7 +3332,11 @@
         strcat(dev,path);
+#if 0
     printf("Trying to mount %s on %s\n",dev,mntpoint);
+#else
+    printf("Mounting %s\n",dev);
+#endif
     if (mount(dev,
               mntpoint,
On 04/26/2012 10:42 AM, Kate Feng wrote:
1. In RTEMS-4.10, the nfsMount wrapper is blocked out in the file cpukit/libfs/src/nfsclient/src/nfs.c
    Instead, it was moved to EPICS-3.14.12.1 in the file src/RTEMS/base/rtems_init.c
    However, it does not work.  My work around was to unblock the nfsMount wrapper in the
    cpukit/libfs/src/nfsclient/src/nfs.c in RTEMS-4.10.
2. You can try to use RTEMS4-10.1 because there were many patches applied since RTEMS4-10.0,
    although one still need to unblock the nfsMount wrapper in cpukit/libfs/src/nfsclient/src/nfs.c.
3. However, there was a minor bug with NFS in RTEMS4-10.1, which did not exist in RTEMS4-10.0.
    The bug needs to be fixed. I will try to fix it starting today.  I am still using RTEMS4-10.0 with all the
    patches I have sent to RTEMS.  This version is robust.
    They are
   Cheers,
   Kate Feng
On 04/26/2012 02:24 AM, 송영기 wrote:
Hi all,
I successfully installed the autosave-4.8 with RTEMS-4.9.2 and EPICS base-3.14.12.1.
I would like to use the autosave with the RTEMS-4.10 and EPICS base-3.14.12.1.
So, i installed them (RTEMS + base) and tried to install the autosave-4.8.
But an error occured as follows:
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/ -specs bsp_specs -qrtems -fasm -c -fno-strict-aliasing -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring -mstrict-align -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -DBSP_NVRAM_BASE_ADDR=0xf1110000 -MMD -I. -I../O.Common -I. -I../os/RTEMS -I../os/default -I.. -I../.../../include/os/RTEMS -I../../../include -I/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/include/os/RTEMS -I/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/include ../os/RTEMS/osdNfs.c
.../os/RTEMS/osdNfs.c: In function 'mountFileSystem':
.../os/RTEMS/osdNfs.c:44: warning: implicit declaration of function 'nfsMount'
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-ar rc libautosave.a dbrestore.o save_restore.o initHooks.o fGetDateStr.o osdNfs.o
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-ranlib libautosave.a
echo "Installing library ../../../lib/RTEMS-mvme5500/libautosave.a"
perl /usr/local/epics/base_ppc/rtems410/base-3.14.12.1/bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/as.dbd as_registerRecordDeviceDriver /usr/local/epics/base_ppc/rtems410/autosave-4-8 > as.tmp
/bin/mv as.tmp as_registerRecordDeviceDriver.cpp
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/ -specs bsp_specs -qrtems -c -fno-strict-aliasing -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring -mstrict-align -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -DBSP_NVRAM_BASE_ADDR=0xf1110000 -MMD -I. -I../O.Common -I. -I../os/RTEMS -I../os/default -I.. -I../../../include/os/RTEMS -I../../../include -I/usr/local/epics/base_ppc/rtems410/base-3.14..12.1/include/os/RTEMS -I/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/include as_registerRecordDeviceDriver.cpp
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/ -specs bsp_specs -qrtems -c -fno-strict-aliasing -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring -mstrict-align -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -DBSP_NVRAM_BASE_ADDR=0xf1110000 -MMD -I. -I../O.Common -I. -I../os/RTEMS -I../os/default -I.. -I../../../include/os/RTEMS -I../../../include -I/usr/local/epics/base_ppc/rtems410/base-3.14..12.1/include/os/RTEMS -I/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/include ../asMain.cpp
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/ -specs bsp_specs -qrtems -o asApp -static -L/usr/local/epics/base_ppc/rtems410/autosave-4-8/lib/RTEMS-mvme5500 -L/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/lib/RTEMS-mvme5500 -fno-strict-aliasing -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring -mstrict-align -u Init /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-dpmem.rel /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-mp.rel /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-part.rel /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-signal.rel /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-rtmon.rel as_registerRecordDeviceDriver.o asMain.o -lautosave -l re cI oc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lreadline -lncurses -lbspExt -lm -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm
/usr/local/epics/base_ppc/rtems410/autosave-4-8/lib/RTEMS-mvme5500/libautosave.a(osdNfs.o): In function `mountFileSystem':
/usr/local/epics/base_ppc/rtems410/autosave-4-8/asApp/src/O.RTEMS-mvme5500/.../os/RTEMS/osdNfs.c:44: undefined reference to `nfsMount'
collect2: ld returned 1 exit status
make[3]: *** [asApp] Error 1
make[3]: Leaving directory `/usr/local/epics/base_ppc/rtems410/autosave-4-8/asApp/src/O.RTEMS-mvme5500'
make[2]: *** [install.RTEMS-mvme5500] Error 2
make[2]: Leaving directory `/usr/local/epics/base_ppc/rtems410/autosave-4-8/asApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/local/epics/base_ppc/rtems410/autosave-4-8/asApp'
make: *** [asApp.install] Error 2
I checked the librtemsNfs.h.
I found the nfsMount function in RTEMS4.9.2-4.9.6.
But the RTEMS4.10.0 doesn't include the nfsMount function.
What is the difference between both RTEMS versions?
How can i install the autosave with RTEMS4.10?
Thanks and Best Regards,
Young-gi
Re: EPICS3.14.12 RTEMS patch for nfsMount() ( was Re: Autosave and RTEMS-4.10) Andrew Johnson
Autosave and RTEMS-4.10 송영기
Re: Autosave and RTEMS-4.10 Kate Feng
Prev: Re: Channel Access monitoring tools Ralph Lange
Next: RE: using areaDetector as a support library only Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Autosave and RTEMS-4.10 Kate Feng
Next: Re: EPICS3.14.12 RTEMS patch for nfsMount() ( was Re: Autosave and RTEMS-4.10) Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
