Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Subject: Re: Channel Access monitoring tools
From: Benjamin Franksen <benjamin.franksen@helmholtz-berlin.de>
To: <tech-talk@aps.anl.gov>
Date: Tue, 15 May 2012 12:59:00 +0200
On Tuesday, May 15, 2012, you wrote:
> > > At present, I am doing something like this:
> > > 1.  Invoke ca_create_channel() with a connection state change
> > > handler.
> > >     The connection state change handler sets a flag to indicate that
> > >     the connection has complete.
> > > 2.  Call ca_pend_io() to make sure the request is sent on its way.
> > You want to use ca_flush (or was it called ca_flush_io?) for that.
> > AFAIK ca_pend_io does not send accumulated requests, it just waits for
> > responses (and other events).
> > Cheers
> > Ben
> I'm not sure about that.  The first sentence of the description for
> ca_pend_io() says:
>   Flushes the send buffer and then waits until outstanding queries
> complete or the specified time out expires.
> When I look at the source code for EPICS Base 3.14.12.2, I see that
> ca_pend_io() gets a ca_client_context object in the variable "pcac" and
> then calls the pcac->pendIO() method of that object.  The pendIO()
> method, in turn calls the this->flush() method of the same object.
> ca_flush_io() instead directly calls pcac->flush() on the context
> object.  So it looks like ca_pend_io() does everything that
> ca_flush_io() does and more.
Sorry for the misinformation, then.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Channel Access monitoring tools Bill Lavender
Re: Channel Access monitoring tools Benjamin Franksen
Re: Channel Access monitoring tools Bill Lavender
Prev: FW: Problem installing CA for QT Andrew Rhyder
Next: Re: Channel Access monitoring tools Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Prev: Re: Channel Access monitoring tools Bill Lavender
Next: RE: Channel Access monitoring tools Hill, Jeff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
