g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: FW: Problem installing CA for QT
From: Andrew Rhyder <Andrew.Rhyder@synchrotron.org.au>
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Tue, 15 May 2012 12:53:45 +1000
Like hinko says. -lqwt6 or -lqwt as appropriate.
By the way, an alternative to building qwt as part of the EPICS Qt package is to use qwt as installed on your box (if installed)
Comment out the qwt line in the main project file epicsqt.pro as follows:
SUBDIRS = \
#    ca_framework/qwt \
    ca_framework/plugins \
    applications/ASguiApp \
    applications/QCaMonitorApp
and In the epics plugin project file ...ca_framework/plugins/plugins.pro, comment out the library reference to qwt as follows:
LIBS += -L$$(EPICS_BASE)/lib/$$(EPICS_HOST_ARCH) \
    -lca \
    -lCom \
#    -L$$(QCAFRAMEWORK)/qwt/lib \
    -lqwt6
( qwt library reference will still need to be either -lqwt6 or -lqwt)
Regards
Andrew
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] On Behalf Of Hinko Kocevar [hinko.kocevar@i-tech.si]
Sent: Monday, 14 May 2012 6:06 PM
To: tech-talk@aps.anl.gov
Subject: Re: Problem installing CA for QT
On 05/14/2012 09:26 AM, manta santosh aditya santosh_aditya wrote:
> I have set the QCAFRAMEWORK as specified in the previous mail..previous
> problem is solved but a new problem is raised....
> /usr/bin/ld -lqwt6 not found...i searched over the net but in vain...i
> am attaching the output of 'env' command and actual error.
Try using lqwt library instead of lqwt6, it depends on the Linux distro
which library is installed/present and what is the filename of the
library actually named.
Best regards,
Hinko
> please help me in this regard
> thank you
> Santosh
> */-- Original Message --/*
> To: manta santosh aditya santosh_aditya <santosh_aditya@ecil.co.in>,
> Date: Mon, 7 May 2012 09:20:46 +1000
> Subject: RE: Problem installing CA for QT
> Hi Santosh
> Have you defined the environment variable QCAFRAMEWORK?
> In your case it would need to be
> export QCAFRAMEWORK=/home/santosh/Downloads/epicsqt/ca_framework
> If that doesn’t work, perhaps send me a copy the entire build output as
> well as the output from the ‘env’ command.
> Regards
> Andrew
> *From:*tech-talk-bounces@aps.anl.gov
> [mailto:tech-talk-bounces@aps.anl.gov] *On Behalf Of *manta santosh
> *Sent:* Friday, 4 May 2012 11:45 PM
> *To:* tech-talk@aps.anl.gov
> *Subject:* Problem installing CA for QT
> Hi,
> I download software for Channel Access for QT and extracted the tar
> file. when building the pro file i am getting the following error:
> /myepics/base/include -Irelease -I. -o release/QCaSpinBoxPluginManager.o
> src/QCaSpinBoxPluginManager.cpp
> src/QCaSpinBoxPluginManager.cpp:32:37: fatal error:
> QCaSpinBoxPluginManager.h: No such file or directory
> compilation terminated.
> make[2]: *** [release/QCaSpinBoxPluginManager.o] Error 1
> make[2]: Leaving directory
> `/home/santosh/Downloads/epicsqt/ca_framework/plugins'
> make[1]: *** [release] Error 2
> make[1]: Leaving directory
> make: *** [sub-ca_framework-plugins-make_default-ordered] Error 2*
> Please help me in this regard
> M SANTOSH ADITYA
> SSSD, ECIL
> Phone: 040-27182914, 040-27182977
> "I cannot give you the formula for success, but I can give you the
> formula for failure--which is - Try to please everybody".
> - Herbert Bayard Swope
> ::DISCLAIMER::
> The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only.
> It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in
> this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates.
> Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of
> this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have
> received this email in error please delete it and notify the sender immediately. Before opening any mail and
> attachments please check them for viruses and defect.
> THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
> This message and any attachments may contain proprietary or confidential
> information. If you are not the intended recipient or you received the
> message in error, you must not use, copy or distribute the message.
> Please notify the sender immediately and destroy the original message.
> Thank you.
> ::DISCLAIMER:: -----------------------------------------------------------------------------------------------  The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only. It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates. Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have received this email in error please delete it and notify the sender immediately. Before opening any mail and attachments please check them for viruses and defect.  THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
> ::DISCLAIMER::
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: hinko.kocevar@i-tech.si
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: RE: Problem installing CA for QT manta santosh aditya santosh_aditya
Re: Problem installing CA for QT Hinko Kocevar
Prev: Re: Channel Access monitoring tools Bill Lavender
Next: Re: Channel Access monitoring tools Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: Problem installing CA for QT Hinko Kocevar
Next: RE: Writing mbbo/mbbi text labels using asynPortDriver/areaDetector Mark Rivers
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
