Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Subject: Re: Regarding access of Process Variable
To: tech-talk@aps.anl.gov
Date: Mon, 14 May 2012 19:01:38 +0200
Dear manta santosh aditya,
from the information given I can only direct you to the Channel Access Reference Manual where the environment variables are described. Maybe you need to set the IP addresses of your CA IOCs in one or more of those variables to get your CA clients working.
It helped me on VPN ;)
HTH,
Hinko
On 05/03/2012 08:10 AM, manta santosh aditya santosh_aditya wrote:
How can I access the process variable that is on other system connected
over LAN in the same VLAN? Please help me in this regard
M SANTOSH ADITYA
SSSD, ECIL
Phone: 040-27182914, 040-27182977
"I cannot give you the formula for success, but I can give you the
formula for failure--which is - Try to please everybody".
- Herbert Bayard Swope
::DISCLAIMER::
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only.
It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in
this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates.
Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of
this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have
received this email in error please delete it and notify the sender immediately. Before opening any mail and
attachments please check them for viruses and defect.
THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
Regarding access of Process Variable manta santosh aditya santosh_aditya
Prev: Re: cPCI express Urša Rojec
Next: Re: cPCI express Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Prev: Regarding access of Process Variable manta santosh aditya santosh_aditya
Next: labCa build fails on 64 bit Windows james.rowland
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
