On 05/14/2012 09:26 AM, manta santosh aditya santosh_aditya wrote:
I have set the QCAFRAMEWORK as specified in the previous mail..previous
problem is solved but a new problem is raised....
/usr/bin/ld -lqwt6 not found...i searched over the net but in vain...i
am attaching the output of 'env' command and actual error.
Try using lqwt library instead of lqwt6, it depends on the Linux distro
which library is installed/present and what is the filename of the
library actually named.
Best regards,
Hinko
please help me in this regard
thank you
Santosh
*/-- Original Message --/*
From: Andrew Rhyder <Andrew.Rhyder@synchrotron.org.au>
To: manta santosh aditya santosh_aditya <santosh_aditya@ecil.co.in>,
"tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 7 May 2012 09:20:46 +1000
Subject: RE: Problem installing CA for QT
Hi Santosh
Have you defined the environment variable QCAFRAMEWORK?
In your case it would need to be
export QCAFRAMEWORK=/home/santosh/Downloads/epicsqt/ca_framework
If that doesn’t work, perhaps send me a copy the entire build output as
well as the output from the ‘env’ command.
Regards
Andrew
[mailto:tech-talk-bounces@aps.anl.gov] *On Behalf Of *manta santosh
*Sent:* Friday, 4 May 2012 11:45 PM
*To:* tech-talk@aps.anl.gov
*Subject:* Problem installing CA for QT
I download software for Channel Access for QT and extracted the tar
file. when building the pro file i am getting the following error:
/myepics/base/include -Irelease -I. -o release/QCaSpinBoxPluginManager.o
src/QCaSpinBoxPluginManager.cpp
src/QCaSpinBoxPluginManager.cpp:32:37: fatal error:
QCaSpinBoxPluginManager.h: No such file or directory
compilation terminated.
make[2]: *** [release/QCaSpinBoxPluginManager.o] Error 1
make[2]: Leaving directory
`/home/santosh/Downloads/epicsqt/ca_framework/plugins'
make[1]: *** [release] Error 2
make[1]: Leaving directory
make: *** [sub-ca_framework-plugins-make_default-ordered] Error 2*
Please help me in this regard
M SANTOSH ADITYA
SSSD, ECIL
Phone: 040-27182914, 040-27182977
"I cannot give you the formula for success, but I can give you the
formula for failure--which is - Try to please everybody".
- Herbert Bayard Swope
::DISCLAIMER::
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only.
It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in
this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates.
Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of
this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have
received this email in error please delete it and notify the sender immediately. Before opening any mail and
attachments please check them for viruses and defect.
THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
This message and any attachments may contain proprietary or confidential
information. If you are not the intended recipient or you received the
message in error, you must not use, copy or distribute the message.
Please notify the sender immediately and destroy the original message.
Thank you.
::DISCLAIMER:: ----------------------------------------------------------------------------------------------- The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only. It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates. Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have received this email in error please delete it and notify the sender immediately. Before opening any mail and attachments please check them for viruses and defect. THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
::DISCLAIMER::
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: hinko.kocevar@i-tech.si
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
- FW: Problem installing CA for QT Andrew Rhyder
- Re: RE: Problem installing CA for QT manta santosh aditya santosh_aditya
Re: Channel Access monitoring tools Benjamin Franksen
<2012>
<2012>
