g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: RE: Problem installing CA for QT
From: manta santosh aditya santosh_aditya <santosh_aditya@ecil.co.in>
To: Andrew Rhyder <Andrew.Rhyder@synchrotron.org.au>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 14 May 2012 12:56:37 +0530 (IST)
I have set the QCAFRAMEWORK as specified in the previous mail..previous problem is solved but a new problem is raised....
/usr/bin/ld -lqwt6 not found...i searched over the net but in vain...i am attaching the output of 'env' command and actual error.
please help me in this regard
thank you
Santosh
-- Original Message --
From: Andrew Rhyder <Andrew.Rhyder@synchrotron.org.au>
To: manta santosh aditya santosh_aditya <santosh_aditya@ecil.co.in>,
Date: Mon, 7 May 2012 09:20:46 +1000
Subject: RE: Problem installing CA for QT
Hi Santosh
Have you defined the environment variable QCAFRAMEWORK?
In your case it would need to be
export QCAFRAMEWORK=/home/santosh/Downloads/epicsqt/ca_framework
If that doesn’t work, perhaps send me a copy the entire build output as well as the output from the ‘env’ command.
Regards
Andrew
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of manta santosh aditya santosh_aditya
Sent: Friday, 4 May 2012 11:45 PM
To: tech-talk@aps.anl.gov
Subject: Problem installing CA for QT
I download software for Channel Access for QT and extracted the tar file. when building the pro file i am getting the following error:
/myepics/base/include -Irelease -I. -o release/QCaSpinBoxPluginManager.o src/QCaSpinBoxPluginManager.cpp
src/QCaSpinBoxPluginManager.cpp:32:37: fatal error: QCaSpinBoxPluginManager.h: No such file or directory
compilation terminated.
make[2]: *** [release/QCaSpinBoxPluginManager.o] Error 1
make[2]: Leaving directory `/home/santosh/Downloads/epicsqt/ca_framework/plugins'
make[1]: *** [release] Error 2
make[1]: Leaving directory `/home/santosh/Downloads/epicsqt/ca_framework/plugins'
make: *** [sub-ca_framework-plugins-make_default-ordered] Error 2
Please help me in this regard
M SANTOSH ADITYA
SSSD, ECIL
Phone: 040-27182914, 040-27182977
"I cannot give you the formula for success, but I can give you the formula for failure--which is - Try to please everybody".
- Herbert Bayard Swope
::DISCLAIMER::
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only.
It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in
this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates.
Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of
this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have
received this email in error please delete it and notify the sender immediately. Before opening any mail and
attachments please check them for viruses and defect.
THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
::DISCLAIMER:: -----------------------------------------------------------------------------------------------  The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only. It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates. Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have received this email in error please delete it and notify the sender immediately. Before opening any mail and attachments please check them for viruses and defect.  THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
::DISCLAIMER::
XDG_VTNR=1
EDMOBJECTS=/home/sssd/edm/prefs
EPICS_CAS_INTF_ADDR_LIST=localhost
XDG_SESSION_ID=2
HOSTNAME=localhost.localdomain
IMSETTINGS_INTEGRATE_DESKTOP=yes
GPG_AGENT_INFO=/tmp/keyring-fkmwqr/gpg:0:1
TERM=xterm
SHELL=/bin/bash
QCAFRAMEWORK=/home/sssd/Documents/epicsqt/ca_framework/
XDG_SESSION_COOKIE=e629fcb807636e320980dc460000000e-1336971008.393284-58444808
EDMCOLORFILE=/home/sssd/edm/prefs/color.list
HISTSIZE=1000
GJS_DEBUG_OUTPUT=stderr
EDMHELPFILES=/home/sssd/myepics/extensions/src/edm/helpFiles
WINDOWID=31457285
OLDPWD=/home/sssd/Documents/epicsqt/ca_framework
GNOME_KEYRING_CONTROL=/tmp/keyring-fkmwqr
GJS_DEBUG_TOPICS=JS ERROR;JS LOG
EDMPVOBJECTS=/home/sssd/edm/prefs
NO_PROXY=localhost,127.0.0.0/8
IMSETTINGS_MODULE=none
http_proxy=http://172.18.0.200:8080/
USER=sssd
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.tbz=01;31:*.tbz2=01;31:*.bz=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.axa=01;36:*.oga=01;36:*.spx=01;36:*.xspf=01;36:*.pdf=00;33:*.ps=00;33:*.ps.gz=00;33:*.txt=00;33:*.patch=00;33:*.diff=00;33:*.log=00;33:*.tex=00;33:*.xls=00;33:*.xlsx=00;33:*.ppt=00;33:*.pptx=00;33:*.rtf=00;33:*.doc=00;33:*.docx=00;33:*.odt=00;33:*.ods=00;33:*.odp=00;33:*.xml=00;33:*.epub=00;33:*.abw=00;33:*.html=00;33:*.wpd=00;33:
LD_LIBRARY_PATH=/home/sssd/myepics/extensions/lib/linux-x86
EPICS_BASE=/home/sssd/myepics/base
SSH_AUTH_SOCK=/tmp/keyring-fkmwqr/ssh
USERNAME=sssd
SESSION_MANAGER=local/unix:@/tmp/.ICE-unix/1500,unix/unix:/tmp/.ICE-unix/1500
EPICS_EXTENSIONS=/home/sssd/myepics/extensions
EPICS_CA_AUTO_ADDR_LIST=NO
DESKTOP_SESSION=gnome
MAIL=/var/spool/mail/sssd
PATH=/usr/lib/ccache:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/sssd/.local/bin:/home/sssd/bin:/home/sssd/myepics/extensions/bin/linux-x86
EPICS_HOST_ARCH=linux-x86
QT_IM_MODULE=xim
EDMLIBS=/home/sssd/myepics/extensions/lib/linux-x86
EDMFILES=/home/sssd/myepics/extensions/edm/prefs
XMODIFIERS=@im=none
GNOME_KEYRING_PID=1491
LANG=en_US.UTF-8
KDE_IS_PRELINKED=1
EPICS_CA_ADDR_LIST=localhost
KDEDIRS=/usr
GDMSESSION=gnome
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
HISTCONTROL=ignoredups
SHLVL=2
HOME=/home/sssd
XDG_SEAT=seat0
no_proxy=localhost,127.0.0.0/8
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
HTTP_PROXY=http://172.18.0.200:8080/
LOGNAME=sssd
CVS_RSH=ssh
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-XTFMAbG87q,guid=597de05a03a5188c93ad44ce00000156
LESSOPEN=||/usr/bin/lesspipe.sh %s
WINDOWPATH=1
XDG_RUNTIME_DIR=/run/user/sssd
DISPLAY=:0
XAUTHORITY=/var/run/gdm/auth-for-sssd-Z0MSdN/database
COLORTERM=gnome-terminal
_=/usr/bin/env
cd ca_framework/qwt/ && make -f Makefile
make[1]: Entering directory `/home/sssd/Documents/epicsqt/ca_framework/qwt'
cd src/ && make -f Makefile
make[2]: Entering directory `/home/sssd/Documents/epicsqt/ca_framework/qwt/src'
make[2]: Nothing to be done for `first'.
make[2]: Leaving directory `/home/sssd/Documents/epicsqt/ca_framework/qwt/src'
cd textengines/ && make -f Makefile
make[2]: Entering directory `/home/sssd/Documents/epicsqt/ca_framework/qwt/textengines'
cd mathml/ && make -f Makefile
make[3]: Entering directory `/home/sssd/Documents/epicsqt/ca_framework/qwt/textengines/mathml'
make[3]: Nothing to be done for `first'.
make[3]: Leaving directory `/home/sssd/Documents/epicsqt/ca_framework/qwt/textengines/mathml'
make[2]: Leaving directory `/home/sssd/Documents/epicsqt/ca_framework/qwt/textengines'
cd designer/ && make -f Makefile
make[2]: Entering directory `/home/sssd/Documents/epicsqt/ca_framework/qwt/designer'
make[2]: Leaving directory `/home/sssd/Documents/epicsqt/ca_framework/qwt/designer'
make[1]: Leaving directory `/home/sssd/Documents/epicsqt/ca_framework/qwt'
cd ca_framework/plugins/ && make -f Makefile
make[1]: Entering directory `/home/sssd/Documents/epicsqt/ca_framework/plugins'
make -f Makefile.Release
/usr/bin/ld: cannot find -lqwt6
collect2: ld returned 1 exit status
make[2]: *** [libQCaPlugin.so] Error 1
make[2]: Leaving directory `/home/sssd/Documents/epicsqt/ca_framework/plugins'
make[1]: Leaving directory `/home/sssd/Documents/epicsqt/ca_framework/plugins'
Re: Problem installing CA for QT Hinko Kocevar
RE: Problem installing CA for QT Andrew Rhyder
Prev: Re: [aSub] using external libraries Eric Norum
Next: Re: Problem installing CA for QT Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: Problem installing CA for QT Andrew Rhyder
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
