1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [CA][waveform] how to NELM?
To: Matthieu Bec <[email protected]>
Date: Mon, 14 May 2012 00:50:38 +0400
Hello Matthieu and Rod,
Thank you! I have finally succeeded! Caget.c is really a good example.
On Sat, May 12, 2012 at 6:57 PM, Matthieu Bec <[email protected]> wrote:
Hello Pavel,
look at the mechanics in catools/caget.c for inspiration.
your last attempt segfaults because at one point or another you need to provide a buffer with sufficient (usually allocated) space to hold the result. when that happens depends on the 'callback' flag - in your synchronous case, follow callback=false.
your first attempt seemed somewhat closer because you did malloc.
Regards
Matthieu
On 05/12/12 00:27, Pavel Masloff wrote:
It's a strange thing. On Windows (VisualStudio 2010) this code works
despite the warning, on Linux I get segmentation fault.
I should have written pValue = wave.value but in this case it doesn't
work even on Windows.
Can anyone check my code? I need to read a waveform (FTVL=UCHAR) via CA
in C.
On Sat, May 12, 2012 at 1:26 AM, Pavel Masloff <[email protected]
<mailto:pavel.masloff@gmail.com>> wrote:
   Alright, here it works. If someone's interested:
   #include <stddef.h>
   #include <stdlib.h>
   #include <stdio.h>
   #include <string.h>
   #include "cadef.h"
   const char *channel_state_str[4] = {
   "not found",
   "connection lost",
   "connected",
   "closed"
   typedef struct {
        chid channel;
        int status;
        long value;
   } epicsShortPV;
   typedef struct {
        chid channel;
        int status;
        long number;
        unsigned short* value;
   } epicsWavePV;
   /* Connect a PV to a channel */
   #define casearch(name, pv) SEVCHK(\
        (pv).status = (ca_search((name), &(pv).channel)), name)
   /* get full information about a PV */
   #define cainfo(pv, type) SEVCHK(\
        (pv).status = (ca_state((pv).channel) != cs_conn ? ECA_DISCONN : \
        ca_get(dbf_type_to_DBR(type), (pv).channel, &(pv).value)),
   ca_name((pv).channel))
   /* get only usually changing information about a PV */
   #define caget(pv, type) SEVCHK(\
        ca_get(dbf_type_to_DBR_STS(type), (pv).channel, &(pv).data)),
   void printPV(const epicsShortPV* pv)
        if (ca_state(pv->channel) == cs_conn)
            printf("%s =  %d \n", ca_name(pv->channel), pv->value);
        else
            printf("%s: <%s>\n",ca_name(pv->channel),
   channel_state_str[ca_state(pv->channel)]);
   int main(int argc,char** argv)
        int i;
        char* pValue;
        epicsShortPV nelm, nord;
        epicsWavePV wave;
        double search_timeout = 5.0;
        double get_timeout = 1.0;
        ca_task_initialize();
        casearch("file.NELM", nelm);
        casearch("file.NORD", nord);
        casearch("file", wave);
        SEVCHK(ca_pend_io(search_timeout), "casearch");
   /*ca_get(dbf_type_to_DBR(DBR_LONG),nelm.channel,(void*)&nelm.value);
   ca_get(dbf_type_to_DBR(DBR_LONG),nord.channel,(void*)&nord.value);*/
        cainfo(nelm, DBF_LONG);
        cainfo(nord, DBF_LONG);
            ca_array_get(DBR_CHAR, 10, wave.channel, (char*)&wave.value);
            SEVCHK(ca_pend_io(get_timeout), "cainfo");
        printPV(&nelm);
        printPV(&nord);
        pValue = & wave.value;
        for(i=0;i<10;i++)        printf("%d ", pValue[i]);
        ca_task_exit();
            return 0;
   One thing I can't get, though everything works fine. The compiler
   goes with a warning at the line pValue = & wave.value :
   warning C4047: '=' : 'char *' differs in levels of indirection from
   'unsigned short **'
   How can it be fixed (if nesessary)?
   Thanks.
   On Fri, May 11, 2012 at 7:32 PM, Mark Rivers
   <[email protected] <mailto:[email protected].edu>> wrote:
       I don't have much experience with writing CA clients in C, I
       mostly use IDL, Java, Python, etc.  Perhaps someone else can help.
       <mailto:pavel.masloff@gmail.com>]
       Sent: Friday, May 11, 2012 9:07 AM
       To: Mark Rivers
       Cc: EPICS Tech Talk
       Thanks, Mark! It works if I am reading just one PV. But when I
       am reading 2 PVs - (waveform and NELM), my NELM value is
       enormously big!!!
       How can I read several PVs?
       This is my code:
       #include <stddef.h>
       #include <stdlib.h>
       #include <stdio.h>
       #include <string.h>
       #include "cadef.h"
       int main(int argc,char **argv)
           int data;         /* NELM */
           chid mychid;
           chid chan;        /* WAVEFORM - file*/
           int status;
           unsigned elementCount, nBytes, i;
           struct dbr_time_char * pTD;
           const dbr_char_t * pValue;
         SEVCHK(ca_context_create(ca_disable_preemptive_callback),"ca_context_create");
         SEVCHK(ca_create_channel("file.NORD",NULL,NULL,10,&mychid),"ca_create_channel failure");
           SEVCHK(ca_pend_io(1.0),"ca_pend_io failure");
           SEVCHK(ca_get(DBR_INT,mychid,(void *)&data),"ca_get failure");
           printf("file.NORD: %d\n",data);
           ca_clear_channel ( mychid );
           ca_task_exit ();
           status = ca_create_channel ( argv[1], 0, 0, 0, & chan );
           ca_search(argv[1], &chan);
           SEVCHK ( status, "ca_create_channel()" );
           status = ca_pend_io ( 1.0 );
           if ( status != ECA_NORMAL ) {
               fprintf ( stderr, "\"%s\" not found.\n", argv[1] );
               return -1;
           elementCount = ca_element_count ( chan );
           nBytes = dbr_size_n ( DBR_TIME_CHAR, elementCount );
           pTD = ( struct dbr_time_char * ) malloc ( nBytes );
           if ( ! pTD ) {
               fprintf ( stderr, "insufficient memory to complete
       request\n" );
               return -1;
           status = ca_array_get (DBR_TIME_CHAR, elementCount, chan, pTD );
           SEVCHK ( status, "ca_array_get()" );
               fprintf ( stderr, "\"%s\" didnt return a value.\n",
       argv[1] );
               return -1;
           pValue = & pTD->value;
           for ( i = 0; i < 10; i++ )    printf("%d ", pValue[i]);
           printf("\nTotal size: %d\n", elementCount);
           printf("Timestamp: %d\n", pTD->stamp.nsec);
           ca_clear_channel ( chan );
           free ( pTD );
           return(0);
       On Fri, May 11, 2012 at 3:42 PM, Mark Rivers
       <[email protected]
       <mailto:[email protected].edu><mailto:rivers@cars.uchicago.edu <mailto:[email protected].edu>>>
       wrote:
       You can just do a ca_get of record.NELM.
       <mailto:tech-talk-bounces@aps.anl.gov><mailto:tech-talk-[email protected]
       <mailto:tech-talk-bounces@aps.anl.gov>>
       [[email protected]
       <mailto:tech-talk-bounces@aps.anl.gov>>] on behalf of Pavel
       Masloff [[email protected]
       <mailto:pavel.masloff@gmail.com><mailto:pavel.masloff@gmail.com
       <mailto:pavel.masloff@gmail.com>>]
       Sent: Friday, May 11, 2012 6:39 AM
       To: EPICS Tech Talk
       Subject: [CA][waveform] how to NELM?
       I am writing a simple CA client in C.
       The client reads the waveform record. And I need to know how
       many elements there are in it (NELM field).
       There is a function entitled ca_element_count() which happens to
       read the NORD field.
       Does anybody know how can I get the NELM field ?
       Best regards,
       Pavel Maslov, MS
       Controls Engineer at Pulsed power Lab
       Efremov Institute for Electro-Physical Apparatus
       St. Petersburg, Russia
       Mobile: +7 (951) 672 22 19
       Landline: +7 (812) 461 01 01
       Best regards,
       Pavel Maslov, MS
   Best regards,
   Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
Matthieu Bec                GMTO Corp.
cell:  +1 626 354 9367      P.O. Box 90933
phone: +1 626 204 0527      Pasadena, CA 91109-0933
Best regards,
Pavel Maslov, MS
[CA][waveform] how to NELM? Pavel Masloff
RE: [CA][waveform] how to NELM? Mark Rivers
Re: [CA][waveform] how to NELM? Pavel Masloff
Re: [CA][waveform] how to NELM? Matthieu Bec
Prev: [aSub] using external libraries Pavel Masloff
Next: Re: [aSub] using external libraries Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [CA][waveform] how to NELM? Matthieu Bec
Next: 'reconnect' in asyn / streamDevice Emmanuel Mayssat
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
