1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [CA][waveform] how to NELM?
Date: Sat, 12 May 2012 12:38:00 +0400
 I have tried to solve it using the Primitive C Data Type :
typedef struct {
    chid channel;
    int status;
    long number;
    dbr_char_t value;
} epicsWavePV;
int main(int argc,char** argv)
   const dbr_char_t* pValue;
   epicsWavePV wave;
   ca_array_get(DBR_CHAR, 10, wave.channel, &wave.value);
   pValue = &wave.value;
   for(i=0;i<10;i++)        printf("%d ", pValue[i]);
And it compiles and runs (now without error during compilation) on Windows.
I then compile it on Linux. Compilation no errors. Run and get: Segmentation fault.
It seems I have to allocate memory for my wave structure (as in CA reference manual http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Channel).
My program, though, is partially based upon Dirk's caTutorial.
Strange, strange... Are there any C clients programmers out there?
Pavel.
On Sat, May 12, 2012 at 11:27 AM, Pavel Masloff <[email protected]> wrote:
It's a strange thing. On Windows (VisualStudio 2010) this code works despite the warning, on Linux I get segmentation fault.
I should have written pValue = wave.value but in this case it doesn't work even on Windows.
Can anyone check my code? I need to read a waveform (FTVL=UCHAR) via CA in C.
On Sat, May 12, 2012 at 1:26 AM, Pavel Masloff <[email protected]> wrote:
Alright, here it works. If someone's interested:
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "cadef.h"
const char *channel_state_str[4] = {
    "not found",
    "connection lost",
    "connected",
    "closed"
typedef struct {
    chid channel;
    int status;
    long value;
} epicsShortPV;
typedef struct {
    chid channel;
    int status;
    long number;
    unsigned short* value;
} epicsWavePV;
/* Connect a PV to a channel */
#define casearch(name, pv) SEVCHK(\
    (pv).status = (ca_search((name), &(pv).channel)), name)
/* get full information about a PV */
#define cainfo(pv, type) SEVCHK(\
    (pv).status = (ca_state((pv).channel) != cs_conn ? ECA_DISCONN : \
    ca_get(dbf_type_to_DBR(type), (pv).channel, &(pv).value)), ca_name((pv).channel))
/* get only usually changing information about a PV */
#define caget(pv, type) SEVCHK(\
    ca_get(dbf_type_to_DBR_STS(type), (pv).channel, &(pv).data)), ca_name((pv).channel))
void printPV(const epicsShortPV* pv)
    if (ca_state(pv->channel) == cs_conn)
        printf("%s =  %d \n", ca_name(pv->channel), pv->value);
    else
        printf("%s: <%s>\n",ca_name(pv->channel), channel_state_str[ca_state(pv->channel)]);
    int i;
    char* pValue;
    epicsShortPV nelm, nord;
    epicsWavePV wave;
    double search_timeout = 5.0;
    double get_timeout = 1.0;
    ca_task_initialize();
    casearch("file.NELM", nelm);
    casearch("file.NORD", nord);
    casearch("file", wave);
    SEVCHK(ca_pend_io(search_timeout), "casearch");
    /*ca_get(dbf_type_to_DBR(DBR_LONG),nelm.channel,(void*)&nelm.value);
    ca_get(dbf_type_to_DBR(DBR_LONG),nord.channel,(void*)&nord.value);*/
    cainfo(nelm, DBF_LONG);
    cainfo(nord, DBF_LONG);
        ca_array_get(DBR_CHAR, 10, wave.channel, (char*)&wave.value);
        SEVCHK(ca_pend_io(get_timeout), "cainfo");
    printPV(&nelm);
    printPV(&nord);
    pValue = & wave.value;
    ca_task_exit();
        return 0;
One thing I can't get, though everything works fine. The compiler goes with a warning at the line pValue = & wave.value :
warning C4047: '=' : 'char *' differs in levels of indirection from 'unsigned short **'
How can it be fixed (if nesessary)?
Thanks.
On Fri, May 11, 2012 at 7:32 PM, Mark Rivers <[email protected]> wrote:
I don't have much experience with writing CA clients in C, I mostly use IDL, Java, Python, etc.  Perhaps someone else can help.
Sent: Friday, May 11, 2012 9:07 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Thanks, Mark! It works if I am reading just one PV. But when I am reading 2 PVs - (waveform and NELM), my NELM value is enormously big!!!
How can I read several PVs?
This is my code:
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "cadef.h"
int main(int argc,char **argv)
   int data;         /* NELM */
   chid mychid;
   chid chan;        /* WAVEFORM - file*/
   int status;
   unsigned elementCount, nBytes, i;
   struct dbr_time_char * pTD;
   const dbr_char_t * pValue;
   SEVCHK(ca_context_create(ca_disable_preemptive_callback),"ca_context_create");
   SEVCHK(ca_create_channel("file.NORD",NULL,NULL,10,&mychid),"ca_create_channel failure");
   SEVCHK(ca_pend_io(1.0),"ca_pend_io failure");
   SEVCHK(ca_get(DBR_INT,mychid,(void *)&data),"ca_get failure");
   printf("file.NORD: %d\n",data);
   ca_clear_channel ( mychid );
   ca_task_exit ();
   status = ca_create_channel ( argv[1], 0, 0, 0, & chan );
   ca_search(argv[1], &chan);
   SEVCHK ( status, "ca_create_channel()" );
   status = ca_pend_io ( 1.0 );
   if ( status != ECA_NORMAL ) {
       fprintf ( stderr, "\"%s\" not found.\n", argv[1] );
       return -1;
   elementCount = ca_element_count ( chan );
   nBytes = dbr_size_n ( DBR_TIME_CHAR, elementCount );
   pTD = ( struct dbr_time_char * ) malloc ( nBytes );
   if ( ! pTD ) {
       fprintf ( stderr, "insufficient memory to complete request\n" );
       return -1;
   status = ca_array_get (DBR_TIME_CHAR, elementCount, chan, pTD );
   SEVCHK ( status, "ca_array_get()" );
       fprintf ( stderr, "\"%s\" didnt return a value.\n", argv[1] );
       return -1;
   pValue = & pTD->value;
   for ( i = 0; i < 10; i++ )    printf("%d ", pValue[i]);
   printf("\nTotal size: %d\n", elementCount);
   printf("Timestamp: %d\n", pTD->stamp.nsec);
   ca_clear_channel ( chan );
   free ( pTD );
   return(0);
On Fri, May 11, 2012 at 3:42 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
You can just do a ca_get of record.NELM.
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of Pavel Masloff [[email protected]<mailto:[email protected]>]
Sent: Friday, May 11, 2012 6:39 AM
To: EPICS Tech Talk
Subject: [CA][waveform] how to NELM?
I am writing a simple CA client in C.
The client reads the waveform record. And I need to know how many elements there are in it (NELM field).
There is a function entitled ca_element_count() which happens to read the NORD field.
Does anybody know how can I get the NELM field ?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
[CA][waveform] how to NELM? Pavel Masloff
RE: [CA][waveform] how to NELM? Mark Rivers
Re: [CA][waveform] how to NELM? Pavel Masloff
Prev: Re: [CA][waveform] how to NELM? Pavel Masloff
Next: Re: [CA][waveform] how to NELM? Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
