1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 'reconnect' in asyn / streamDevice
To: Emmanuel Mayssat <[email protected]>, epics <[email protected]>
Date: Fri, 11 May 2012 10:13:35 -0700 (PDT)
Explicit 'disconnect' was required in protocol.
FYI.
Emmanuel
To: epics <[email protected]>
Sent: Friday, May 11, 2012 9:51 AM
Subject: 'reconnect' in asyn / streamDevice
I have a webserver type device.
The connection 'breaks' at the end of each successful request.
With asyn autoconnect feature, it seems that at least one request should fail for asyn to attempt to reconnect.
With stream, I intended to use the 'connect 1000' at the beginning of my protocols, but it doesn't seem to work.
(Now that I think of it, maybe I should explicitly disconnect at the end)
So currently I have 50% of my requests that fail.
What is the solution?
Emmanuel
'reconnect' in asyn / streamDevice Emmanuel Mayssat
Prev: Re: 'reconnect' in asyn / streamDevice Eric Norum
Next: Channel Access monitoring tools Bill Lavender
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
