Replace "Eclipse" with "Netbeans" in Kay's mail to get the instructions
for Netbeans. More or less.
This is not an endorsement, btw. Personally I am using QtCreator for
EPICS developments, as I find it a lot faster and less heavyweight than
the big Java based IDEs. Kay's instructions would be roughly valid after
replacing "Eclipse" with "Qt Creator" in that case.
~Ralph
On 10.05.2012 22:54, Kasemir, Kay wrote:
> Hi:
> Since EPICS is just C/C++ code, I have been using the basic Eclipse IDE
> for C/C++ developers for EPICS development.
> I create EPICS apps with makeBaseApp.pl as usual, it still builds from the
> command line, but most of the time I edit it from within Eclipse.
> Basic steps:
> 1. Create the application via makeBaseApp.pl as usual, outside of Eclipse,
> or use existing code.
> 2. In Eclipse, create a new "project" for the application: Select C or C++
> "Makefile project", an "Empty Project" for "Linux GCC" or whatever you use
> for the EPICS development.
> Name the project as you named your makeBaseApp project, for example
> "my_app", but do NOT use the "default location"; uncheck that option and
> instead browse to the existing makeBaseApp-created directory like
> /home/epics/.../my_app.
> Ignore the "Directory .. already exists" warning, click "Next",... "Finish"
> 3. In the "Make Targets" view, you can create new make targets for
> "my_app" which invoke "make" with targets like "all", "clean" or maybe
> "distclean".
> Now you can edit your code with the syntax-highlighting editor in the IDE,
> invoke "make" and jump to errors right away, navigate the code to find
> definitions of stuff in header files and so on.
> You can also use the existing support for CVS, subversion, mercurial, git,
> ... in Eclipse.
> Ken Evans @ APS had once developed a plugin that basically provides an
> Eclipse frontend to makeBaseApp:
> You configure it in a dialog, then it calls makeBaseApp to create the
> project etc.
> I don't know if that's still maintained.
> DESY has been developing an SNL editor, see
> http://sourceforge.net/apps/trac/cs-studio/wiki/SnlEditor, that you could
> include in your site-specific CSS product.
> -Kay
> On 5/10/12 16:21 , "Zhou, Jingchen" <jingchen@slac.stanford.edu> wrote:
>> Is there any site using Eclipse for EPICS development? I know CSS is
>> completely developed with Eclipse in many sites. Here I mean the
>> development for EPICS device support, modules, extensions, SNL, IOC
>> applications and etc. It would be great if you can share your experiences
>> with us. Also, what are the Eclipse plugin available for the development,
>> e.g., plugin for VDCT?
>> Thank you very much!
>> Jingchen
- Re: Eclipse for EPICS development Kasemir, Kay
Eclipse for EPICS development Matthias Clausen
<2012>
modbus questions Pierrick Hanlet
<2012>
