g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: seq-2.1.6 build problem on Linux
From: Benjamin Franksen <benjamin.franksen@helmholtz-berlin.de>
To: <tech-talk@aps.anl.gov>
Date: Thu, 10 May 2012 03:57:01 +0200
Am Mittwoch, 9. Mai 2012, 20:42:03 schrieb William F. Steele:
> Build failed due to missing header files. Upon investigating, I found that
> the line: USR_CFLAGS += -I$(TOP)/src/seq
> in makefiles in the
> src/dev
> /test/unit
> directories does not work (the '-I' option does not appear in the compile
> command in the build output). Adding the line:
> USR_INCLUDES += -I$(TOP)/src/seq
> to the 2 makefiles solved the problem.
> Building seq-2.1.6 on Debian Linux.
> William Steele
Thanks for reporting (and solving!) this.
This fix will be in 2.1.7.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
seq-2.1.6 build problem on Linux William F. Steele
Prev: seq-2.1.6 build problem on Linux William F. Steele
Next: RE: Motor model 3 support for OMS MAXv-8000? Jens . Eden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: Eclipse for EPICS development Matthias Clausen
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
