1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: seq-2.1.6 build problem on Linux
To: [email protected]
Date: Wed, 9 May 2012 11:42:03 -0700
Build failed due to missing header files. Upon investigating, I found that the line:
USR_CFLAGS += -I$(TOP)/src/seq
in makefiles in the
src/dev
/test/unit
directories does not work (the '-I' option does not appear in the compile command in the build output).
Adding the line:
USR_INCLUDES += -I$(TOP)/src/seq
to the 2 makefiles solved the problem.
Building seq-2.1.6 on Debian Linux.
William Steele
Re: seq-2.1.6 build problem on Linux Benjamin Franksen
Prev: RE: modbus questions Mark Rivers
Next: Re: seq-2.1.6 build problem on Linux Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: mvme5100 questions Bai Jiaoni
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
