g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: RE: labCa build fails on 64 bit Windows
To: <ernesto@slac.stanford.edu>, <tech-talk@aps.anl.gov>
Date: Tue, 8 May 2012 08:36:57 +0000
Thanks, static would be good if it's possible. I'm not sure how that would work with sharing the channel access state between functions.
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] on behalf of Ernest L. Williams Jr. [ernesto@slac.stanford.edu]
Sent: 04 May 2012 19:08
To: Ernest L. Williams Jr.; EPICS Techtalk
Subject: Re: labCa build fails on 64 bit Windows
On 05/04/2012 10:59 AM, Ernest L. Williams Jr. wrote:
> On 05/04/2012 03:44 AM, james.rowland@diamond.ac.uk wrote:
>> Hi Ernest
>> Please can I have the binaries while I work out what's wrong with the Visual Studio 2010 build, I don't have 2008.
> Sure.
> I will zip it up and mail it to you.
> Or maybe, I should create a static executable?
I meant library
> Cheers,
> Ernest
>> James
>>> -----Original Message-----
>>> From: Ernest L. Williams Jr. [mailto:ernesto@slac.stanford.edu]
>>> Sent: 03 May 2012 22:33
>>> To: Till Straumann
>>> Cc: Rowland, James (DLSLtd,RAL,DIA); tech-talk@aps.anl.gov
>>> On 05/03/2012 09:12 AM, Till Straumann wrote:
>>>> I built it on 64-bit windows7 for matlab 2011a. I don't recall what
>>>> compiler version
>>> Hi,
>>> I used MS Visual Studio 2010
>>> I can provide binaries as well. :)
>>> Cheers,
>>> Ernest.
>>>> was used. Maybe Ernest can fill us in. He should also have access to
>>>> the binaries; if you're lucky they work for you.
>>>> - Till
>>>> On 05/03/2012 06:06 AM, james.rowland@diamond.ac.uk wrote:
>>>>> Hi
>>>>> Has anyone got labCa 3.4 to build on windows-64? If so, what
>>>>> combination of Matlab, Windows and Compiler are you using. I can't
>>>>> get it to work with Windows Server 2008, MatlabR2011b, Visual Studio
>>>>> 2010, EPICS 3.14.12.1
>>>>> Initially the build fails building ezcaglue with some missing libraries:
>>>>> link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
>>> /release   /MACHINE:X64    c:/ma
>>>>> tlab2011b/extern/lib/win64/microsoft/libut.lib
>>>>> c:/matlab2011b/extern/lib/win64/microsoft/libmx.lib c
>>> :/matlab2011b/extern/lib/win64/microsoft/libmex.lib  /implib:mezcaglue.lib
>>> /out:mezcaglue.dll
>>>>>        ini.obj multiEzca.obj ctrlC-polled.obj mglue.obj
>>> ..\\..\\lib\\windows-x64\\ezcamt.lib  d:\ep
>>>>> ics\r3.14.12.1\base\\lib\\windows-x64\\ca.lib
>>>>> d:\epics\r3.14.12.1\base\\lib\\windows-x64\\Com.lib u ser32.lib
>>>>>        Creating library mezcaglue.lib and object mezcaglue.exp
>>>>> ca.lib(ca_client_context.obj) : error LNK2001: unresolved external
>>>>> symbol __imp_bind etc.
>>>>> Adding ws2_32 and advapi32 to USR_SYS_LIBS fixes this but the mex functions
>>> fail:
>>>>> make[2]: Entering directory
>>>>> `S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab/O.windo
>>>>> ws-
>>>>> x64'
>>>>> c:/matlab2011b/bin/mex.bat   -DMATLAB_APP  ../lcaGetNelem.c -I. -
>>> I../O.Common -I. -I.. -I../../inclu
>>>>> de/os/WIN32 -I../../include -Id:\epics\r3.14.12.1\base/include/os/WIN32 -
>>>>> nclude         -I../../ezca -I../../glue      ../../lib/windows-
>>> x64/mezcaglue.lib  ../../lib/windows
>>>>> -x64/ezcamt.lib  d:\epics\r3.14.12.1\base/lib/windows-x64/ca.lib
>>>>> ws-x64/Com.lib  ../../lib/windows-x64/ezcamt.lib
>>>>> d:\epics\r3.14.12.1\base/lib/windows-x64/ca.lib  d
>>>>> :\epics\r3.14.12.1\base/lib/windows-x64/Com.lib ws2_32.lib advapi32.lib
>>> ws2_32.lib advapi32.lib user 32.lib kernel32.lib winmm.lib
>>>>>        Creating library
>>>>> C:\Users\jr76\AppData\Local\Temp\3\mex_JqkfYu\templib.x and object
>>>>> C:\Users\jr76 \AppData\Local\Temp\3\mex_JqkfYu\templib.exp
>>>>> lcaGetNelem.obj : error LNK2019: unresolved external symbol
>>>>> __imp_ezcaFree referenced in function me xFunction
>>>>> lcaGetNelem.mexw64 : fatal error LNK1120: 1 unresolved externals
>>>>>       C:\MATLAB~1\BIN\MEX.PL: Error: Link of 'lcaGetNelem.mexw64' failed.
>>>>> make[2]: *** [lcaGetNelem.mexw64] Error 2
>>>>> make[2]: Leaving directory
>>>>> ws-x
>>>>> 64'
>>>>> make[1]: *** [install.windows-x64] Error 2
>>>>> make[1]: Leaving directory
>>> `S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab'
>>>>> make: *** [matlab.install] Error 2
>>>>> S:\Technical\Controls\Software\Matlab\Build\labca_3_4>
>>>>> James
Re: labCa build fails on 64 bit Windows Till Straumann
labCa build fails on 64 bit Windows james.rowland
Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
RE: labCa build fails on 64 bit Windows james.rowland
Prev: RE: Writing mbbo/mbbi text labels using asynPortDriver/areaDetector Mark Rivers
Next: Re: labCa build fails on 64 bit Windows Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
