1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Scopes] BMP image record??
To: Pavel Masloff <[email protected]>
Date: Fri, 4 May 2012 10:14:13 -0700
I thought that I'd give this a try here so I dug up an old Tektronix TDS 210 oscilloscope with a serial port and connected it to my OS X machine through a LAN/Serial adapter.
Here are the salient portions of my st.cmd file:
drvAsynIPPortConfigure("L0","xxxxxx.lbl.gov:4095 COM",0,0,0)
asynSetOption("L0", 0, "baud", "9600")        <<<<===== Scope has a 19200 setting, but can't seem to accept commands at that rate.  Perhaps if I had a cable that did the right things with the handshaking lines I could set crtscts=Y and run at 19200
asynSetOption("L0", 0, "bits", "8")
asynSetOption("L0", 0, "parity", "none")
asynSetOption("L0", 0, "stop", "1")
asynSetOption("L0", 0, "clocal", "Y")
asynSetOption("L0", 0, "crtscts", "N")
dbpf hctest:HCparms.PROC 1
epicsThreadSleep(1)
dbpr hctest:HCparms
dbpf hctest:HC.PROC 1
epicsThreadSleep(60)
dbpr hctest:HC 1
The StreamDevice prototype file:
getHC {
    InTerminator = "";
    ReplyTimeout = 5000;
    ReadTimeout = 2000;
    out "HARDC STAR";
    in "%0r";
getHCparms {
    out "HARDC?";
    in "%\$1[^\r\n]";
    ExtraInput = Ignore;
The EPICS database:
record(stringin, "$(P)$(R)HCparms")
    field(DESC, "Hardcopy parameters")
    field(DTYP, "stream")
    field(INP,  "@devhctest.proto getHCparms(39) $(PORT) $(A)")
record(waveform, "$(P)$(R)HC")
    field(DESC, "Hardcopy")
    field(INP,  "@devhctest.proto getHC(99999) $(PORT) $(A)")
    field(FTVL, "CHAR")
    field(NELM, "100000")
I''ve found this to be quite solid in reading out the screen dump.   Here's a typical IOC session:
DBR_UCHAR:          1         0x1
epicsThreadSleep(1)
dbpr hctest:HCparms
ASG:                DESC: Hardcopy parameters               DISA: 0
DISP: 0             DISV: 1             NAME: hctest:HCparms
SEVR: NO_ALARM      STAT: NO_ALARM      SVAL:               TPRO: 0
VAL: BMP;RS232;LANDSCAPE
DBR_UCHAR:          1         0x1
dbpr hctest:HC
ASG:                BUSY: 0             DESC: Hardcopy      DISA: 0
DISP: 0             DISV: 1             NAME: hctest:HC     NORD: 38462
SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0             VAL: 0x0
However…
  - just reading out the waveform values would be significantly quicker.
  - 9600 baud RS-232 seems like a pretty horrible way to communicate with an oscilloscope.
Eric Norum
[email protected]
[Scopes] BMP image record?? Pavel Masloff
RE: [Scopes] BMP image record?? Mark Rivers
Re: [Scopes] BMP image record?? Pavel Masloff
Re: [Scopes] BMP image record?? Rod Nussbaumer
Re: [Scopes] BMP image record?? Eric Norum
Prev: RE: undefined symbol:MAXvSetup Mark Rivers
Next: Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [Scopes] BMP image record?? Pavel Masloff
Next: RE: [Scopes] BMP image record?? Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
