Mark, Jeff,
Thanks for the clarification.
The Rabbit CA server code and documentation, along with the Cosylab CA documentation gives a clear picture of what I need.
Graham
We are planning on changing from using ModBus to CA for the link between EPICS and our in-house low-powered embedded controllers (ones using Rabbit Core Modules from Digi), so
I have recently finished writing and debugging a CA server that could run on this low-end hardware. In the process I found several errors and a number of places with very confusing and/or contradictory wording that required examination of other working implementations
to sort out.
For the READ_NOTIFY response, where it says that the SID should be returned (parameter 5), it appears that this should really be the status code (e.g. ECA_NORMAL).
This is not only supported by examination of the values sent by other implementations, but by this statement in section
13 of the spec on Return Codes:
"Return codes are communicated in the protocol by the
CA_PROTO_READ_NOTIFY, CA_PROTO_WRITE_NOTIFY, monitor subscription responses, and the CA_PROTO_ERROR responses."
No doubt you could dig in to the EPICS source code to find the definitive answer to this and similar issues.
If it is of use to anyone else, my implementation and notes can be found here:
https://groups.nscl.msu.edu/controls/
Just download the Rabbit_ST_xxx.zip file and look at the epics_cad.c file in the
daemons sub-directory for the code, and the CA_and_ModBus_on_Rabbit_SBCs.doc file in the
Documentation sub-directory for my analysis and comments on the CA protocol spec (note that this document is itself a bit out of date and contains some of its own errors, and will be updated shortly).
On 5/2/2012 7:12 AM, [email protected] wrote:
All,
According to the Channel Access protocol specification from the Cosylab website, parameter 1 of the header of a CA_PROTO_READ_NOTIFY response contains the channel SID (the same as the request header received).
Is this correct? Monitoring network traffic from a 3.14.12 win32-x86 soft IOC, this value always appears to a fixed value of 1, no matter what the serverID, or clientID of the channel. Returning anything other than 1 also appears to break
correct functioning of a caget.
Graham
Header
Field
Value
Description
Command
15
Command identifier for CA_PROTO_READ_NOTIFY.
Payload size
Size of payload
Size of DBR formatted data in payload.
Data type
DBR type
Payload format.
Data count
>= 0
Payload element count.
SID
Same as request
SID of the channel.
IOID
Same as request
IOID of this operation.
Scanned by iCritical.
