Ø
According to the Channel Access protocol specification from the
Cosylab website,
Ø
parameter 1 of the header of a CA_PROTO_READ_NOTIFY response contains the
Ø
channel SID (the same as the request header received).
typedef
struct ca_hdr {
ca_uint16_t m_cmmd;
/* operation to be performed */
ca_uint16_t m_postsize;
/* size of payload */
ca_uint16_t m_dataType;
/* operation data type */
ca_uint16_t m_count;
/* operation data count */
ca_uint32_t m_cid;
/* channel identifier */
ca_uint32_t m_available;
/* protocol stub dependent */
caHdr;
The
m_cid field in the CA_PROTO_READ_NOTIFY response message header
communicates the CA status (see
caerr.h) of the request, as it was executed in the
server, with this request type.
Jeff
All,
According to the Channel Access protocol specification from the Cosylab website, parameter 1 of the header of a CA_PROTO_READ_NOTIFY response contains the channel SID (the same as the request
header received).
Is this correct? Monitoring network traffic from a 3.14.12 win32-x86 soft IOC, this value always appears to a fixed value of 1, no matter what the serverID, or clientID of the channel.
Returning anything other than 1 also appears to break correct functioning of a caget.
Graham
Header
Field
Value
Description
Command
15
Command identifier for CA_PROTO_READ_NOTIFY.
Payload size
Size of payload
Size of DBR formatted data in payload.
Data type
DBR type
Payload format.
Data count
>= 0
Payload element count.
SID
Same as request
SID of the channel.
IOID
Same as request
IOID of this operation.
Scanned by iCritical.
