1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: AreaDetector Roper or PVCam IOC link problem
To: <[email protected]>, <[email protected]>
Date: Tue, 1 May 2012 11:28:09 +0000
Thanks Mark,
The issue is resolved by building with asyn R4-17.
    giles...
Sent: 30 April 2012 19:50
To: Knap, Giles (DLSLtd,RAL,DIA); [email protected]
Hi Giles,
The functions you list were added in asyn R4-17, but you are linking with asyn R4-14.
This is from the release notes for R4-17 at http://www.aps.anl.gov/epics/modules/soft/asyn/R4-18/RELEASE_NOTES.html
Added 3 new asynPortDriver methods: setUInt32DigitalInterrupt, clearUInt32Interrupt, getUInt32Interrupt. These were needed to complete the
asynUInt32Digital support.
What version of areaDetector are you trying to build?  areaDetector R1-7 lists asyn R4-17 as the (minimum) release needed.
Cheers,
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Monday, April 30, 2012 12:53 PM
To: [email protected]
Subject: AreaDetector Roper or PVCam IOC link problem
Hello All,
I am trying to build an IOC on windows 32 to drive a princeton instruments CCD via AreaDetector.  The exisiting roper or pvcam drivers should both be able to control this device.
I am getting the same link issue when I try to build an IOC with either of these drivers. I am getting unresolved externals in either roper.lib or pvcam.lib. The externals appear to be asynportdriver methods but are named a little differently to the actual functions in asynportdriver. I cannot discover where these dependencies are coming from despite investigating the code for both lib files.
The symbols in question are:
    getUInt32DigitalInterrupt@asynPortDriver
    clearUInt32DigitalInterrupt@asynPortDriver
    setUInt32DigitalInterrupt@asynPortDriver
They do not seem to appear in any versions of asyn that I looked in. (I am trying to link against asyn 4-14)
Detailed output from the link is pasted below.
Any pointers appreciated.
   giles...
link -nologo  /LTCG /incremental:no /opt:ref /release               -out:BL16I-EA-IOC-11.exe       BL16I-EA-IOC-11_regis
terRecordDeviceDriver.obj BL16I-EA-IOC-11Main.obj     W:/prod/R3.14.11/support/dxp/3-0dls3/lib/win32-x86/dxp.lib  W:/pro
d/R3.14.11/support/dxp/3-0dls3/lib/win32-x86/handel.lib  W:/prod/R3.14.11/support/seq/2-0-12dls1/lib/win32-x86/seq.lib
W:/prod/R3.14.11/support/seq/2-0-12dls1/lib/win32-x86/pv.lib  C:/epics/support/areaDetector/lib/win32-x86/roper.lib  W:/
epics/R3.14.11/base/lib/win32-x86/recIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/softDevIoc.lib  W:/epics/R3.14.11/bas
e/lib/win32-x86/miscIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/rsrvIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/dbto
olsIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/asIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/dbIoc.lib  W:/epics/R3.
14.11/base/lib/win32-x86/registryIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/dbStaticIoc.lib  W:/epics/R3.14.11/base/l
ib/win32-x86/ca.lib  W:/epics/R3.14.11/base/lib/win32-x86/Com.lib  W:/prod/R3.14.11/support/dxp/3-0dls3/lib/win32-x86/DL
PORTIO.lib  W:/prod/R3.14.11/support/dxp/3-0dls3/lib/win32-x86/PlxApi.lib  C:/epics/support/areaDetector/lib/win32-x86/N
DPlugin.lib  C:/epics/support/areaDetector/lib/win32-x86/ADBase.lib  C:/epics/support/areaDetector/lib/win32-x86/netCDF.
lib  W:/prod/R3.14.11/support/calc/2-8dls2/lib/win32-x86/calc.lib  W:/prod/R3.14.11/support/busy/1-3dls3/lib/win32-x86/b
usy.lib  W:/prod/R3.14.11/support/sscan/2-6-6dls1/lib/win32-x86/sscan.lib  W:/prod/R3.14.11/support/autosave/4-6dls2/lib
/win32-x86/autosave.lib  W:/prod/R3.14.11/support/mca/6-12-4dls1/lib/win32-x86/mca.lib  W:/prod/R3.14.11/support/asyn/4-
14/lib/win32-x86/asyn.lib  W:/epics/R3.14.11/base/lib/win32-x86/recIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/softDev
Ioc.lib  W:/epics/R3.14.11/base/lib/win32-x86/miscIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/rsrvIoc.lib  W:/epics/R3
.14.11/base/lib/win32-x86/dbtoolsIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/asIoc.lib  W:/epics/R3.14.11/base/lib/win
32-x86/dbIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/registryIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/dbStaticIoc
.lib  W:/epics/R3.14.11/base/lib/win32-x86/ca.lib  W:/epics/R3.14.11/base/lib/win32-x86/Com.lib  C:/epics/support/areaDe
tector/lib/win32-x86/PvAPI.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_Magick++_.lib  C:/epics/support/area
Detector/lib/win32-x86/CORE_RL_wand_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_magick_.lib  C:/epics/supp
ort/areaDetector/lib/win32-x86/CORE_RL_coders_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_filters_.lib  C:
/epics/support/areaDetector/lib/win32-x86/CORE_RL_bzlib_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_jbig_.
lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_jp2_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_j
peg_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_lcms_.lib  C:/epics/support/areaDetector/lib/win32-x86/COR
E_RL_libxml_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_png_.lib  C:/epics/support/areaDetector/lib/win32-
x86/CORE_RL_tiff_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_ttf_.lib  C:/epics/support/areaDetector/lib/w
in32-x86/CORE_RL_wmf_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_xlib_.lib  C:/epics/support/areaDetector/
lib/win32-x86/CORE_RL_zlib_.lib  C:/epics/support/areaDetector/lib/win32-x86/NeXus.lib  C:/epics/support/areaDetector/li
b/win32-x86/hdf5dll.lib  C:/epics/support/areaDetector/lib/win32-x86/szip.lib  C:/epics/support/areaDetector/lib/win32-x
86/zlib1.lib setupapi.lib ole32.lib oleaut32.lib Gdi32.lib Oleaut32.lib ws2_32.lib advapi32.lib user32.lib kernel32.lib
winmm.lib
nafxcw.lib(afxmem.obj) : error LNK2005: "void * __cdecl operator new(unsigned int)" (??2@YAPAXI@Z) already defined in LI
BCMT.lib(new.obj)
nafxcw.lib(afxmem.obj) : error LNK2005: "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) already defined in LIBCMT.
lib(delete.obj)
nafxcw.lib(afxmem.obj) : error LNK2005: "void * __cdecl operator new[](unsigned int)" (??_U@YAPAXI@Z) already defined in
 LIBCMT.lib(new2.obj)
nafxcw.lib(afxmem.obj) : error LNK2005: "void __cdecl operator delete[](void *)" (??_V@YAXPAX@Z) already defined in LIBC
MT.lib(delete2.obj)
nafxcw.lib(afxmem.obj) : warning LNK4006: "void * __cdecl operator new(unsigned int)" (??2@YAPAXI@Z) already defined in
LIBCMT.lib(new.obj); second definition ignored
nafxcw.lib(afxmem.obj) : warning LNK4006: "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) already defined in LIBCM
T.lib(delete.obj); second definition ignored
nafxcw.lib(afxmem.obj) : warning LNK4006: "void * __cdecl operator new[](unsigned int)" (??_U@YAPAXI@Z) already defined
in LIBCMT.lib(new2.obj); second definition ignored
nafxcw.lib(afxmem.obj) : warning LNK4006: "void __cdecl operator delete[](void *)" (??_V@YAXPAX@Z) already defined in LI
BCMT.lib(delete2.obj); second definition ignored
   Creating library BL16I-EA-IOC-11.lib and object BL16I-EA-IOC-11.exp
roper.lib(roper.obj) : error LNK2001: unresolved external symbol "public: virtual enum asynStatus __thiscall asynPortDri
ver::getUInt32DigitalInterrupt(int,unsigned int *,enum interruptReason)" (?getUInt32DigitalInterrupt@asynPortDriver@@UAE
?AW4asynStatus@@HPAIW4interruptReason@@@Z)
ver::getUInt32DigitalInterrupt(int,int,unsigned int *,enum interruptReason)" (?getUInt32DigitalInterrupt@asynPortDriver@
@UAE?AW4asynStatus@@HHPAIW4interruptReason@@@Z)
ver::clearUInt32DigitalInterrupt(int,unsigned int)" (?clearUInt32DigitalInterrupt@asynPortDriver@@UAE?AW4asynStatus@@HI@
Z)
ver::clearUInt32DigitalInterrupt(int,int,unsigned int)" (?clearUInt32DigitalInterrupt@asynPortDriver@@UAE?AW4asynStatus@
@HHI@Z)
ver::setUInt32DigitalInterrupt(int,unsigned int,enum interruptReason)" (?setUInt32DigitalInterrupt@asynPortDriver@@UAE?A
W4asynStatus@@HIW4interruptReason@@@Z)
ver::setUInt32DigitalInterrupt(int,int,unsigned int,enum interruptReason)" (?setUInt32DigitalInterrupt@asynPortDriver@@U
AE?AW4asynStatus@@HHIW4interruptReason@@@Z)
BL16I-EA-IOC-11.exe : fatal error LNK1120: 6 unresolved externals
AreaDetector Roper or PVCam IOC link problem giles.knap
RE: AreaDetector Roper or PVCam IOC link problem Mark Rivers
Prev: Re: [Scopes] BMP image record?? Pavel Masloff
Next: RE: [Scopes] BMP image record?? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: AreaDetector Roper or PVCam IOC link problem Mark Rivers
Next: OK to make function variable in registryFunction.c static? Ru Igarashi
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
