1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: OK to make function variable in registryFunction.c static?
Date: Mon, 30 Apr 2012 15:25:09 -0600
I was compiling the synApps areaDetector on Cygwin 1.7 under
base 3.14.12.2 using the system libs for netCDF and HDF5 for
fun, but ran into a linker error, complaining that the symbol
"_function" was multiply defined, once in registryIoc.lib and
once in libnetcdf.a.  I tracked the EPICS symbol down to the
"const char *function" variable in BASE/src/registry/registryFunction.c:
const char *function = "function";
static void *registryID = (void *)&function;
Seeing as neither symbols seem to be used outside of that file,
I prepended "static" to the declaration of "*function", recompiled
EPICS, and recompiled areaDetector successfully.  I've only tested
the new base with softIoc, and areaDetector not at all, so by no
means have I adequately tested this hack.  I cannot find any
mention of this particular hack in TechTalk or base Release Notes
or base Known Problems.
Instead, I thought I should ask, is this hack safe (or otherwise
appropriate)?
ru
Ru Igarashi                    Software & Instrumentation Specialist
e-mail: [email protected]   Canadian Light Source
ph:306 657 3751                University of Saskatchewan
fax: 306 657 3535              Saskatoon SK S7N 0X4
Re: OK to make function variable in registryFunction.c static? Andrew Johnson
Prev: Re: [Scopes] BMP image record?? Rod Nussbaumer
Next: Re: OK to make function variable in registryFunction.c static? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: AreaDetector Roper or PVCam IOC link problem giles.knap
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
