1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Scopes] BMP image record??
To: Pavel Masloff <[email protected]>
Date: Mon, 30 Apr 2012 09:59:28 -0500
Hi Pavel,
Since you mentioned pyepics and numpy, I'll jump in to recommend a
slightly different waveform -> Image conversion using these:
    import Image
    import epics
    waveform_pv = epics.PV('xx:waveform.VAL')
    waveform = waveform_pv.get()  # will be a numpy array of unsigned ints
    # to get a truncated waveform, pass in the length you'd like:
    #     waveform = waveform_pv.get(count=400)
    width = ??     # that is, you'll have to assert this here.
    height = len(waveform)/width
    image = Image.frombuffer('L', (width, height), waveform, 'raw', 'L', 0, 1)
    image.show()
where you'll have the know the image height and width somehow to
unravel the 1-d waveform.   The Image.frombuffer() call is slightly
cryptic, but documented ('L' means 8-bit greyscale -- if you're
waveform held RGB data from a color camera, you'd change that here to
get a color image), and is faster than converting to a string and then
using Image.open().
--Matt
Re: [Scopes] BMP image record?? Pavel Masloff
RE: [Scopes] BMP image record?? Mark Rivers
RE: [Scopes] BMP image record?? Wang Xiaoqiang
Prev: 9th NOBUGS conference announcement - registration open Tobias.Richter
Next: AreaDetector Roper or PVCam IOC link problem giles.knap
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [Scopes] BMP image record?? Pavel Masloff
Next: Re: [Scopes] BMP image record?? Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
