I have a Tektronix scope (TPS2024). I am using StreamDevice. I know how to set the scope's parameters. These are simple commands with the SCAN field = PASSIVE. One record (the Trigger Single Sequence button) is causing me some pain. When the scope is triggered (end of measurement), I need a readback signal to change its state (=0). So far my commands were only one way (except for the initializaion). I send, nothing comes. Here is what I use: record(bo, "$(P)$(R)TrigArm") { field(DESC, "Arm the trigger") field(SCAN, "Passive") field(DTYP, "stream") field(OUT, "@devTPS20xx.proto TrigArm $(PORT) $(A)") field(ZNAM, "STOP") field(ONAM, "ARMED") field(PINI, "") } TrigArm { ReplyTimeout = 2000; out "ACQ:STOPA SEQ"; out "ACQ:STATE %{OFF|ON}"; @init { out "ACQ:STATE?"; in "%i"; } } So I need the same @init code in the TrigArm protocol (out "ACQ:STATE?";in "%i";). How can I do that? The "ACQ:STATE?" command will have an answer ("1"=Trigger Armed, "0"=Trigger Not Armed). I have tried using another record (with forward link), but to no avail. -- Best regards, Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia Mobile: +7 (951) 672 22 19 Landline: +7 (812) 461 01 01
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
