g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Autosave and RTEMS-4.10
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Cc:
Date: Thu, 26 Apr 2012 15:24:14 +0900
Hi all,
I successfully installed the autosave-4.8 with RTEMS-4.9.2 and EPICS base-3.14.12.1.
I would like to use the autosave with the RTEMS-4.10 and EPICS base-3.14.12.1.
So, i installed them (RTEMS + base) and tried to install the autosave-4.8.
But an error occured as follows:
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/ -specs bsp_specs -qrtems -fasm -c -fno-strict-aliasing -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring -mstrict-align -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -DBSP_NVRAM_BASE_ADDR=0xf1110000 -MMD -I. -I../O.Common -I. -I../os/RTEMS -I../os/default -I.. -I../.../../include/os/RTEMS -I../../../include -I/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/include/os/RTEMS -I/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/include ../os/RTEMS/osdNfs.c
.../os/RTEMS/osdNfs.c: In function 'mountFileSystem':
.../os/RTEMS/osdNfs.c:44: warning: implicit declaration of function 'nfsMount'
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-ar rc libautosave.a dbrestore.o save_restore.o initHooks.o fGetDateStr.o osdNfs.o
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-ranlib libautosave.a
echo "Installing library ../../../lib/RTEMS-mvme5500/libautosave.a"
perl /usr/local/epics/base_ppc/rtems410/base-3.14.12.1/bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/as.dbd as_registerRecordDeviceDriver /usr/local/epics/base_ppc/rtems410/autosave-4-8 > as.tmp
/bin/mv as.tmp as_registerRecordDeviceDriver.cpp
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/ -specs bsp_specs -qrtems -c -fno-strict-aliasing -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring -mstrict-align -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -DBSP_NVRAM_BASE_ADDR=0xf1110000 -MMD -I. -I../O.Common -I. -I../os/RTEMS -I../os/default -I.. -I../../../include/os/RTEMS -I../../../include -I/usr/local/epics/base_ppc/rtems410/base-3.14..12.1/include/os/RTEMS -I/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/include as_registerRecordDeviceDriver.cpp
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/ -specs bsp_specs -qrtems -c -fno-strict-aliasing -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring -mstrict-align -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -DBSP_NVRAM_BASE_ADDR=0xf1110000 -MMD -I. -I../O.Common -I. -I../os/RTEMS -I../os/default -I.. -I../../../include/os/RTEMS -I../../../include -I/usr/local/epics/base_ppc/rtems410/base-3.14..12.1/include/os/RTEMS -I/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/include ../asMain.cpp
/usr/local/rtems/rtems-4.10/bin/powerpc-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/ -specs bsp_specs -qrtems -o asApp -static -L/usr/local/epics/base_ppc/rtems410/autosave-4-8/lib/RTEMS-mvme5500 -L/usr/local/epics/base_ppc/rtems410/base-3.14.12.1/lib/RTEMS-mvme5500 -fno-strict-aliasing -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec -mvrsave=no -mmultiple -mstring -mstrict-align -u Init /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-dpmem.rel /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-mp.rel /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-part.rel /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-signal.rel /usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme5500/lib/no-rtmon.rel as_registerRecordDeviceDriver.o asMain.o -lautosave -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lreadline -lncurses -lbspExt -lm -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm
/usr/local/epics/base_ppc/rtems410/autosave-4-8/lib/RTEMS-mvme5500/libautosave.a(osdNfs.o): In function `mountFileSystem':
/usr/local/epics/base_ppc/rtems410/autosave-4-8/asApp/src/O.RTEMS-mvme5500/.../os/RTEMS/osdNfs.c:44: undefined reference to `nfsMount'
collect2: ld returned 1 exit status
make[3]: *** [asApp] Error 1
make[3]: Leaving directory `/usr/local/epics/base_ppc/rtems410/autosave-4-8/asApp/src/O.RTEMS-mvme5500'
make[2]: *** [install.RTEMS-mvme5500] Error 2
make[2]: Leaving directory `/usr/local/epics/base_ppc/rtems410/autosave-4-8/asApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/local/epics/base_ppc/rtems410/autosave-4-8/asApp'
make: *** [asApp.install] Error 2
I checked the librtemsNfs.h.
I found the nfsMount function in RTEMS4.9.2-4.9.6.
But the RTEMS4.10.0 doesn't include the nfsMount function.
What is the difference between both RTEMS versions?
How can i install the autosave with RTEMS4.10?
Thanks and Best Regards,
Young-gi
Re: Autosave and RTEMS-4.10 Kate Feng
Prev: RE: Presentation slides for EPICS Training Available Williams Jr., Ernest L.
Next: Re: Autosave and RTEMS-4.10 Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: Fwd: Cosylab MicroIOC/BLM Calibration procedure confusion Uwe Bonnes
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
