I have had some success with embedding a complete EPICS IOC, along
with RTEMS, into an
Altera NIOS2 soft core. I will give some status at
the EPICS meeting. We are using the
Altera NIOS2 enhanced gcc 4.1
source we have patched, configured, and build specially for RTEMS.
Jeff
Hi all,
Last few days ,I am working on porting EPICS in microblaze softcore processor with uClinux. For this I am trying to build a Channel access portable server code on it as referring
the tutorial on Channel Access Portable Server Application Interface (API) by Philip Stanley.
It consists of four c++ files namely myServer.h,Ÿ myPV.cc,Ÿ myServer.cc and Ÿ Server.cc. I could successfully compile the cc files and generate the object files in uClinux
(namely myPV.o myServer.o Server.o). But while generating executable named Server by linking the object files with the libraries libcas.a, libca.a, libCom.a, and libgdd.a i am stuck at an error. microblaze-uclinux-gnu toolchain is used for compilation. I know
my problem is a bit specific, but if anyone who has worked with uclinux earlier may help me.
Following is the error output at the console
microblaze-uclinux-g++ -L/home/petalinux-v0.40-final/software/petalinux-dist/lib -mno-xl-soft-mul -mno-xl-soft-div -mxl-barrel-shift -mcpu=v7.10.d -L/windows/base-3-14-11/myserver2/microblaze_lib
-Wl -o Server myPV.o myServer.o Server.o -lcas -lca -lCom -lgdd -lrt -lc -lpthread
Server.elf2flt: In function `ClockTimeSync': /windows/base-3-14-11/myserver2/libCom/osiClockTime.c(.text+0x815b8): undefined reference to `clock_settime'
Server.elf2flt: In function `ClockTimeGetCurrent':/windows/base-3-14-11/myserver2/libCom/osiClockTime.c(.text+0x816ec): undefined reference to `clock_settime' Server.elf2flt: In function `putDoubleToString(double, gddEnumStringTable const*,
char*, unsigned long)': /windows/base-3-14-11/myserver2/gdd/aitConvert.cc(.text+0x96164): undefined reference to `cvtDoubleToString'
collect2: ld returned 1 exit status
make: *** [Server] Error 1
Shantonu Sahoo
वैज्ञानिक
अधिकारी / Scientific Officer
कंप्यूटर
एवं
सूचना
वर्ग / Computer and Informatics Group
परिवर्ती
ऊर्जा
साइक्लोट्रॉन
केन्द्र / Variable Energy Cyclotron Center
Ph: (033) 23182300
- Problem in porting EPICS on microblaze softcore processor ssahoo
Re: Problem in porting EPICS on microblaze softcore processor Steve Shoaf
SRS PTC10 support? Pete R. Jemian
<2012>
Re: Problem in porting EPICS on microblaze softcore processor Eric Norum
CSS Status bar, general CSS product sermon Kasemir, Kay
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
