Hi All
Below is the response from PPC1-BUG after I tried to run an example
EPICS application created using makeBaseApp.pl -t example.
Please guide me what is happening this time.
Best Regards
Zia
PPC1-Bug>niot
Controller LUN =00?
Device LUN =00?
Node Control Memory Address =07F9E000?
Client IP Address =10.1.22.45?
Server IP Address =10.1.22.70? 10.1.22.69
Subnet IP Address Mask =255.255.255.0?
Broadcast IP Address =255.255.255.255?
Gateway IP Address =10.1.22.1?
Boot File Name ("NULL" for None) =ticker.ralf? first_rtems.boot
Argument File Name ("NULL" for None) =? 10.1.22.69:/tftpboot/st.cmd
Boot File Load Address =001F0000?
Boot File Execution Address =001F0000?
Boot File Execution Delay =00000000?
Boot File Length =00000000?
Boot File Byte Offset =00000000?
BOOTP/RARP Request Retry =00?
TFTP/ARP Request Retry =00?
Trace Character Buffer Address =00000000?
BOOTP/RARP Request Control: Always/When-Needed (A/W)=W?
BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y?
Update Non-Volatile RAM (Y/N)? y
PPC1-Bug>nbo
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci@80000000/pci1011,9@e,0:0,0
Loading: first_rtems.boot
Client IP Address = 10.1.22.45
Server IP Address = 10.1.22.69
Gateway IP Address = 10.1.22.1
Subnet IP Address Mask = 255.255.255.0
Boot File Name = first_rtems.boot
Argument File Name = 10.1.22.69:/tftpboot/st.cmd
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&821600, Bytes Loaded =&821600
Bytes/Second =&136933, Elapsed Time =6 Second(s)
Residual-Data Located at: $07F88000
Model: 000000000000000000000000000(e2)
Serial: MOT07C27F7
Processor/Bus frequencies (Hz): 333361536/66672376
Time Base Divisor: 4000
Memory Size: 8000000
PCI: Probing PCI hardware
RTEMS 4.x/PPC load:
Uncompressing the kernel...
done
Now booting...
Welcome to rtems-4.10.2(PowerPC/Generic (classic FPU)/mvme2304) on MVME 2300
idreg 0 = 0x48011057
OpenPIC found at C1000000.
pci : Configuring interrupt routing for 'MVME 2300'
pci : No bridge from bus 0 towards root found
pci : Unable to match device 0:0x0B:1 with an int routing table entry
Cleared PCI errors: pci_stat was 0x2280
OpenPIC Version ? (2 CPUs and 16 IRQ sources) at 0xC1000000
OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 2
OpenPIC timer frequency is 8333656 Hz
Universe II PCI-VME bridge detected at 0xC1040000, IRQ 11
Universe Master Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0E000000 0x10000000 A32, D64 [MBLT], Dat, Sup
1: 0x00000000 0x00FF0000 0x1F000000 A24, D64 [MBLT], Dat, Sup
2: 0x00000000 0x00010000 0x1FFF0000 A16, D64, Dat, Sup
Universe Slave Ports:
0: 0xC0000000 0x07F80000 0x80000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
Registering /dev/console as minor 0 (==/dev/ttyS0)
Exception handler called for exception 3 (0x3)
Next PC or Address of fault = 000C6294
Saved MSR = 0000B032
Context: Task ID 0x0A010001
R0 = 000000B8 R1 = 001E6E50 R2 = 00000000 R3 = 00000000
R4 = 1A010011 R5 = 00000000 R6 = 001E6DE8 R7 = 00000000
R8 = 0000B032 R9 = FFE81000 R10 = 001ADD00 R11 = 00000001
R12 = 40000084 R13 = 001AFA58 R14 = 00000000 R15 = 00000000
R16 = 00000000 R17 = 00000000 R18 = 00000000 R19 = 00000000
R20 = 00000000 R21 = 00000000 R22 = 00000000 R23 = 00000000
R24 = 00000000 R25 = 00000000 R26 = 00000000 R27 = 00000000
R28 = 00000000 R29 = 001A0000 R30 = 001ADD00 R31 = 0019FE3C
CR = 20000082
CTR = 000000B8
XER = 00000000
LR = 000C6164
DAR = FFE81000
Stack Trace:
IP: 0x000C6294, LR: 0x000C6164
--^ 0x000C6164--^ 0x0010A418--^ 0x0010A33C
Suspending faulting task (0x0A010001)
Startup.
RE: log message filter in Asyn Mark Rivers
Problem: Example IOC in RTEMS-MVME2304 Qazi Zia-ul-Haque
<2012>
CSS Training at EPICS meeting next week: Agenda, what to prepare Kasemir, Kay
<2012>
