Jeff,
Look. I have noticed that even when I am normally starting an IOC on a linux machine, then I get these messages: online_notify.c:CA beacon (send to "172.20.255.255:5065") error was "Connection refused"
When I caget from another terminal window, the messages stop appearing. I stop the IOC. Then restart. No problems. Should I set EPICS_CA_AUTO_BEACON_ADDR_LIST and EPICS_CA_BEACON_ADDR_LIST in linux (bashrc) or in directly in EPICS:
epicsEnvSet("EPICS_CA_AUTO_BEACON_ADDR_LIST","NO") epicsEnvSet("EPICS_CA_BEACON_ADDR_LIST","localhost")
I think it has something to do with the Repeater (because of the port 5065)?
On Mon, Apr 9, 2012 at 4:59 PM, Hill, Jeffrey O <[email protected]> wrote:
Hi Pavel, This probably indicates that the IOC’s IP kernel is unable locate a route to the beacon address 172.20.255.255.
To avoid
this type of warning messages, one can modify the CA server beacon destination addresses, independent of the search message destination addresses, using EPICS_CA_AUTO_BEACON_ADDR_LIST and EPICS_CA_BEACON_ADDR_LIST. The
server configuration chapter in the CA Reference Manual has some of the details.
Jeff
[mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Saturday, April 07, 2012 12:19 AM
To: EPICS Tech Talk
Subject: Channel Access problem over SSH
Hello tech-talkers,
There is an example IOC on a linux machine (Fedora 16) with an IP-address
172.20.92.99/16:
$EPICS_CA_ADDR_LIST=172.20.92.99
$EPICS_CA_AUTO_ADDR_LIST=NO
Which means I can access PVs on the same machine where the IOC is running. It works. No problem.
Now, when I connect to the linux machine via SSH from another machine on the same subnet (Windows XP, Putty), and when I run the IOC from the SSH client, then I get the following message in epics shell (over Putty) every once in a while:
Still the IOC is running, I can caget, caput, camonitor. The Firewall is off. What might be the case?
Pavel
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia
Landline: +7 (812) 461 01 01
- RE: Channel Access problem over SSH michael.abbott
- RE: Channel Access problem over SSH Hill, Jeffrey O
- Channel Access problem over SSH Pavel Masloff
log message filter in Asyn matthew.pearson
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
