1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: procServ softIOC server - V2.6.0 released
To: EPICS Tech Talk <[email protected]>
Date: Mon, 16 Apr 2012 15:50:26 +0200
Hi all,
procServ V2.6.0 has been released. [1]
The probably most attractive new feature:
* procServ now runs on Windows systems, allowing to remotely access
softIOCs on Windows in the same manner as softIOCs on other systems.
The Windows binary (available for download on SourceForge) has been
built under Cygwin and should run on any recent Windows system. It does
not require a full Cygwin installation - putting the Cygwin1.dll runtime
library into an appropriate place (e.g. the same directory) is sufficient.
Other improvements include:
* Log file lines can be time stamped
* Accepts a signal to reopen log file (to work with the logrotate facility)
* Additional control command to close the telnet connection
* Foreground mode that keeps child process in the starting terminal
* Improvements for cross-builds (autotools and EPICS builds)
Full change log at
http://sourceforge.net/apps/trac/procserv/query?milestone=R+2.6
Thanks to Michael Abbott and Dirk Zimoch, who were helping a lot with
beta testing.
procServ is part of the official distributions of Debian/Ubuntu (as
"procserv") and Fedora/RHEL (as "procServ"). New versions usually take a
few days to get into their respective repositories, but will eventually
be available using the standard package managers.
Enjoy!
~Ralph
[1] procServ is a wrapper application that runs any process (e.g. a
softIOC, a CA Gateway, ...) in the background, allowing telnet access to
its stdin/stdout. It supports logging, child restart (manual or
automatic on crash/exit), blocking characters that are considered
dangerous to the child, and much more.
http://sourceforge.net/projects/procserv/
Re: procServ softIOC server - V2.6.0 released Pavel Masloff
RE: procServ softIOC server - V2.6.0 released Mark Rivers
Prev: RTEMS driver for SIS3820 scaler Kate Feng
Next: Re: procServ softIOC server - V2.6.0 released Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: RTEMS driver for SIS3820 scaler Kate Feng
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
