Thanks all.
Lana
-----Original Message-----
Sent: 11 April 2012 22:28
To: [email protected]; Abadie Lana
Subject: Re: DCT flag in record reference manual
Hi Lana,
On 2012-04-11 Lana Abadie wrote:
> 2.TSE field is also marked DCT=no. So again what does it mean? and if
> it is not advised to use in db file then what is the proper way to implement it?
> via TSEL field?
Bob Dalesio replied:
> ----I believe that is right.
> Database Configuration Tool (DCT), was the tool for configuring these
> in the dark ages. Where this field was set to no, it meant that it
> was not to be configured as the initialization and operation of that
> record would overwrite the field. Therefore, the value set in by the
> loaded database would never be used.
Nowadays having DCT=no doesn't really mean much, since we don't have to use the dct program any more to create ASCII databases. You can set fields that have DCT=no in your .db files with no ill effect, but an EPICS-aware database design tool like VDCT doesn't have to make those fields available to you.
There should be little need for it to do so though, since the initial values of fields marked DCT=no are usually ignored and get overwritten by the record support code.
In the particular case of the TSE field though, that should be marked as DCT=yes in R3.14.x since it has a promptgroup() setting in the dbCommon.dbd file (in 3.13.x it did not). I'll fix the record reference manual.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- DCT flag in record reference manual Abadie Lana
- RE: DCT flag in record reference manual Dalesio, Leo
- Re: DCT flag in record reference manual Andrew Johnson
[Fwd: Re: Stream Device parsing strings] Dirk Zimoch
Re: Stream Device parsing strings Rod Nussbaumer
<2012>
<2012>
