I forgot to send this reply to tech-talk...
--- Begin Message ---
Hi Rod,
Separator is ONLY used when reading arrays (e.g. waveform record). It
cannot be used for breaking up the input into several different records.
The problem here is the %s. As in scanf, %s reads up to the next
whitespace, which is not what you want.
I suggest to use %[^;] instead to read up to the next ; (or end of
string) and include whitespace.
Thus your format would look like this:
in "%(\$1PARAM01.VAL)[^;];"
"%(\$1PARAM02.VAL)[^;];"
"%(\$1PARAM03.VAL)[^;];"
"%(\$1PARAM04.VAL)[^;];"
"%(\$1PARAM05.VAL)[^;];"
"%(\$1PARAM06.VAL)[^;];"
"%(\$1PARAM07.VAL)[^;]";
BTW, in the current version of StreamDevice you don't need the .VAL any
more.
Dirk
Rod Nussbaumer wrote:
Hi all.
I am trying to get streamDevice to break an input string that has fields
delimited with semi-colons into discrete strings. The input string as
read by asyn + GPIB looks something like
BIN;RI;MSB;4;32;500;Y;100.00000000000E-12;20.90000000000E-9;"s";0.05000000000;5.00000000000E-9;21.00000000000E-9;0.00500000000;232.83064365387E-12;0.0000;"V";"C2,
50.00mV/div, 5.000ns/div,500 points, Sample mode";"C2"
My stream device protocol looks like:
WFMPRE {
ReplyTimeout = 200;
ReadTimeout = 50;
InTerminator = LF;
Separator = ";";
out "VERBOSE ON";
out "WFMO?";
in
"%(\$1PARAM01.VAL)s%(\$1PARAM02.VAL)s%(\$1PARAM03.VAL)s%(\$1PARAM04.VAL)s%(\$1PARAM05.VAL)s%(\$1PARAM06.VAL)s%(\$1PARAM07.VAL)s";
out "VERBOSE OFF";
where the records referred to by $1PARAMxx.VAL are stringout records
with SoftChannel DTYP. Each successive conversion ends at either the
39th converted character, or the first whitespace. It seems to be
completely ignoring the specified separator. Is this correct behavior?
If so, any suggestions for accomplishing what I want (ability to access
the string fields as records or as string elements of a waveform record.
I intend to add more field conversions to complete the string parsing,
if/when I get this much working.
The data in question comes from a Tektronix scope, and contains the data
need to convert a generically scaled waveform array into an array scaled
to engineering units.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
--- End Message ---
Announce: sequencer release 2.1.6 Benjamin Franksen
RE: DCT flag in record reference manual Abadie Lana
<2012>
RTEMS driver for SIS3820 scaler Kate Feng
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
