Rod,
the "Separator" variable sets the separating character when reading
*array* data into waveform records. (So that it works with any number of
elements.)
In your case of non-array data, just use semicolon characters at the
appropriate positions inside the format string.
Good luck,
~Ralph
On Thu Apr 12 2012 00:01:39 GMT+0200 (CEST), Rod Nussbaumer
<bomr@triumf.ca> wrote:
> Hi all.
> I am trying to get streamDevice to break an input string that has
> fields delimited with semi-colons into discrete strings. The input
> string as read by asyn + GPIB looks something like
>> BIN;RI;MSB;4;32;500;Y;100.00000000000E-12;20.90000000000E-9;"s";0.05000000000;5.00000000000E-9;21.00000000000E-9;0.00500000000;232.83064365387E-12;0.0000;"V";"C2,
>> 50.00mV/div, 5.000ns/div,500 points, Sample mode";"C2"
> My stream device protocol looks like:
>> WFMPRE {
>> ReplyTimeout = 200;
>> ReadTimeout = 50;
>> InTerminator = LF;
>> Separator = ";";
>> out "VERBOSE ON";
>> out "WFMO?";
>> in
>> "%(\$1PARAM01.VAL)s%(\$1PARAM02.VAL)s%(\$1PARAM03.VAL)s%(\$1PARAM04.VAL)s%(\$1PARAM05.VAL)s%(\$1PARAM06.VAL)s%(\$1PARAM07.VAL)s";
>> out "VERBOSE OFF";
> where the records referred to by $1PARAMxx.VAL are stringout records
> with SoftChannel DTYP. Each successive conversion ends at either the
> 39th converted character, or the first whitespace. It seems to be
> completely ignoring the specified separator. Is this correct behavior?
> If so, any suggestions for accomplishing what I want (ability to
> access the string fields as records or as string elements of a
> waveform record. I intend to add more field conversions to complete
> the string parsing, if/when I get this much working.
> The data in question comes from a Tektronix scope, and contains the
> data need to convert a generically scaled waveform array into an array
> scaled to engineering units.
> Thanks.
> Rod Nussbaumer
> ISAC Controls, TRIUMF
> Vancouver, Canada.
- Re: Stream Device parsing strings Rod Nussbaumer
- Stream Device parsing strings Rod Nussbaumer
Announce: sequencer release 2.1.6 Benjamin Franksen
<2012>
<2012>
