1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: DCT flag in record reference manual
To: Abadie Lana <[email protected]>, Tech Talk <[email protected]>
Date: Wed, 11 Apr 2012 17:07:27 +0000
i have the following question.When reading the record reference manual i can see that epics fields are flagged DCT=no.
I would like to make sure that I understand correctly something here:
1. VAL field of output records such as ao are marked DCT=no, does it mean that i can't have in a db file record (ao,"mypv") {
        field(VAL, "12")
and that the proper way to do that would be record (ao,"mypv") {
        field(DOL, "12")
field(OMSL,"supervisory") ->if it is a initial value
field(OMSL,"closed_loop") ->if it is a constant
----Yes that's right.
2.TSE field is also marked DCT=no. So again what does it mean? and if it is not advised to use in db file then what is the proper way to implement it? via TSEL field?
----I believe that is right.
Database Configuration Tool (DCT), was the tool for configuring these in the dark ages. Where this field was set to no, it meant that it was not to be configured as the initialization and operation of that record would overwrite the field. Therefore, the value set in by the loaded database would never be used.
Bob
Re: DCT flag in record reference manual Andrew Johnson
DCT flag in record reference manual Abadie Lana
Prev: DCT flag in record reference manual Abadie Lana
Next: Re: DCT flag in record reference manual Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
