1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Channel Access problem over SSH
To: EPICS Tech Talk <[email protected]>
Date: Sat, 7 Apr 2012 10:18:49 +0400
Hello tech-talkers,
There is an example IOC on a linux machine (Fedora 16) with an IP-address 172.20.92.99/16:
$EPICS_CA_ADDR_LIST=172.20.92.99
$EPICS_CA_AUTO_ADDR_LIST=NO
Which means I can access PVs on the same machine where the IOC is running. It works. No problem.
Now, when I connect to the linux machine via SSH from another machine on the same subnet (Windows XP, Putty), and when I run the IOC from the SSH client, then I get the following message in epics shell (over Putty) every once in a while:
online_notify.c:CA beacon (send to "172.20.255.255:5065") error was "Connection refused"
Still the IOC is running, I can caget, caput, camonitor. The Firewall is off. What might be the case?
Pavel
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
RE: Channel Access problem over SSH Hill, Jeffrey O
Prev: Re: asynPortDriver, I/O INTR and missing updates Eric Norum
Next: RE: asynPortDriver, I/O INTR and missing updates Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: asynPortDriver, I/O INTR and missing updates Mark Rivers
Next: RE: Channel Access problem over SSH Hill, Jeffrey O
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
