We have recently built a number of drivers using asynPortDriver. The process has been extremely easy and the results good. We did run into one problem recently which I’d like to get input on. What we found was that we were missing updates
from one driver when using “I/O INTR”. When we looked into it we discovered it was because the setDouble member of paramList checks to see whether the value being passed to it is different from the current parameter value before if updates its flag for inclusion
as part of callCallbacks.
About 1% of the time the data our driver retrived matched the previous value.
In our case we need the “I/O INTR” records to process regardless of whether the value differs or not (in addition to providing the currrent value it is triggering our servo processing). For now we just modified the asynPortDriver source
but this is not how we want to proceed. Would it be possible to modify the setXXXParam calls to take a third defaulted parameter, e.g.
setDoubleParam(int index,
double value, bool ignorevaluecheck =
false), offer an overloaded set of setXXXParam calls or is there a way to use the current class such that callbacks occur regardless of the value?
Thanks
Jimmy Johnson
- RE: asynPortDriver, I/O INTR and missing updates Mark Rivers
- Re: asynPortDriver, I/O INTR and missing updates Eric Norum
Re: [db] simple command ? Benjamin Franksen
<2012>
RE: a question about sequencer Mark Rivers
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
