1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [db] simple command ?
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Fri, 6 Apr 2012 16:30:28 -0500 (CDT)
----- Original Message -----
> From: "Benjamin Franksen" <[email protected]>
> To: [email protected]
> Sent: Friday, April 6, 2012 5:45:10 PM
> On Wednesday 04 April 2012 18:43:29 Pavel Masloff wrote:
> > You are right - I want the record to automatically switch its value
> > back to
> > 0 after somebody sets it to 1. Time doesn't really matter. Imagine a
> > pneumatic valve. I have two records two control it: cmd:valve_ON and
> > cmd:valve_OFF. The reason I use two records instead of one is simply
> > because there are two buttons on the front panel of my control
> > cubicle. And
> > the PLC logic is that it checks whether only one button is pressed
> > at a
> > time. This is local control. Yet, at the same time I want to
> > remotely
> > control my system by means of EPICS.
> Beware, though: using the HIGH field causes the record to process
> (again) when
> VAL gets reset to zero.
> The bo machinery with all the extra processing, setting up timers etc
> seems to
> be overkill for this commonly requested feature. I tend to use mbbo
> records
> (one for each command) and let clients write to the PROC field (they
> can write
> any value they like).
I understood the problem to require that a pulse be sent to the PLC.  In that case, processing again seems inevitable, and in any case something must define the pulse width.  If a sub-millisecond pulse were ok, you could just forward link to a "reset" record that would write to the VAL field via a CA link.
> One feature that I miss with this solution: a (simple) way to make the
> VAL
> field immutable, so chosing /which/ command is executed cannot be
> changed at
> runtime. Any ideas how to do that except writing a new record type?
When I don't want users writing to a PV, I usually just decline to give them the record name, and instead provide a second record that forward links to it.  If they're well enough informed to figure it out by looking at the forward link, then I assume they know what they're doing and just try to stay out of their way.
If I'm /really/ worried about somebody writing to a record, or if they want the ability to forbid each other from writing to a record, I usually control DISA and DISP, as in this excerpt from the motor module's motor.db (DISV==1):
record(transform, "$(P)$(M)_ableput") {
  field(CLCB, "a")
  field(CLCC, "a")
  field(OUTA, "$(P)$(M).DISA NPP NMS")
  field(OUTB, "$(P)$(M).DISP NPP NMS")
  field(OUTC, "$(P)$(M).DISA NPP NMS")
This isn't bulletproof, because a database link will still succeed in changing $(P)$(M).<field>, even though it won't succeed in processing the record.  It's bulletproof to CA clients, though.
Tim
> Cheers
> Ben
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
> stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführerin: Prof. Dr. Anke Rita Kaysser-Pyzalla
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Re: [db] simple command ? Benjamin Franksen
Prev: RE: Proposed support for additional Modbus data types Mark Rivers
Next: Re: [db] simple command ? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [db] simple command ? Benjamin Franksen
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
